What precautions for a rookie
  1. Riot van Member
    19
    Bristol
    Hi I'm wanting to learn to Mig weld I've bought a second hand Clarke turbo Mig welder. What precautions should I take to start up?
    My ideas were to do the following
    1. Replace earth return wire and clamp on the welder
    2. Buy an auto dimming mask, gauntlets and overalls.
    3. Purchase a co2 fire extinguisher
    Is there anything else I should do? I've heard about the potential to be electrocuted whilst welding how does one avoid this? Wil I be OK as long as the earth wire is secured to the bench or workpiece and in good condition?
    Anything else I should be doing?
    Cheers
    davidjohnperry likes this.
  2. mtt.tr
    mtt.tr Member
    3,132
    Essex England
    electrocution whilst welding is unlikely unless you are welding in the rain in a puddle not much fun
    make sure flammable dust is cleared away such as sawdust
    and the angle grinder enjoys making fires
    SteScouse, skotl, 8ob and 1 other person like this.
  3. stuvy
    stuvy Member
    Keep brake cleaner away from where you weld
    Hold the grinder as tight as possible in both hands and use the guard it’s there for a reason
    Don’t be frightened of it, if there some one in your area ask for tuition offer a lunch for the training. If not look at a college course
    Post pictures and expect honest feedback
    Gragson, atomant48, 8ob and 2 others like this.
  4. barking mat
    barking mat Barking at Pigeons
    3,208
    Brittany, The Arz Valley.
    And no batteries on charge! Car batteries I mean.
    They will go bang, covering you in acid.
    Been there, learnt that one, first welding experience in mates garage.
    Wany, SteScouse, 8ob and 3 others like this.
  5. bourbon Member
    736
    Lichfield UK
    as you can read, It's not so much the welder that is the problem. Usually the sparks don't travel too far. However, has been said, An angle grinder has the potential to throw sparks a lot further and they do tend to set fire to your crotch if you aren't careful
    8ob likes this.
  6. gaz1
    gaz1 Forum Supporter
    10,705
    westyorkshire
    welder not really a problem its getting whats needed is the problem
    wear eye mask and also a mouth mask go cheap if you want or buy a decent one like i have done then can wear with glasses o
    SteScouse, barking mat and 8ob like this.
  7. hotponyshoes Member
    2,741
    Somerset. Uk
    Stop welding and cutting/grinding an hour before you leave the workshop.
    Hang the key for the workshop on the gas bottle so you dont forget to turn it off before you leave.
    Bbe555, Gragson, slim_boy_fat and 5 others like this.
  8. Riot van Member
    19
    Bristol
    What do you mean by mouth mask? Is it required to wear a respirator when welding? I already have one but it's a full face mask that probably wont fit under the welding mask
    Also my welder is a no gas welder I know it won't do the cleanest welds but I guess its OK go learn on since it was inexpensive
  9. gaz1
    10,705
    westyorkshire
  10. You will forever be blaming yourself for poor welds. Upgrade it to full gas and you will be amazed at what you can do. Even more when you can afford a decent machine. I did OK with my Clarke 150TE but boy, did my quality ever improve with the R-Tech 180?
    Wany, barking mat and stuvy like this.
  11. 500e
    500e Always buy fire insurance a flood is hard to start
    4,689
    SWest UK
    Overalls are ok but they still combust especially with grinders they are an invention of Vulcan!!, more fires from them than welders.
    Fleeces burn really well have a couple with large holes, I also have a large selection of colander socks :D cotton usually only goes to holes, I bought a cheap cheap leather coat from charity shop,. gloves are a good thing as well.
    I see people welding with bare arms & legs etc, I burn it is not sensible
    A half tidy auto mask, Look at what Weldaquip sells helps to keep site going.
    We are mostly friendly & helpful here, they might take the proverbial but all in the best of taste, suggestions as to improvement are usually given by people who have more experience than mos of us will ever get & have been working for manufacturers in tech departments\ demonstrators, others with years of on the ground knowledge.
    PS don't leave rags on bench:thumbup:
    davidjohnperry, stuvy and mtt.tr like this.
  12. bourbon Member
    736
    Lichfield UK
  13. SteScouse
    SteScouse Member
    560
    Liverpool
    @gaz1 is spot on re getting PPE sorted as a priority
    Safety specs are £2 or so at Screwfix and Toolstation
    I've tried all 3 of the most readily available respirators. IMO the JSP Force 8 is the best, cheapest replacement filters too
    Fits under hood ok
    stuvy likes this.
  14. SteScouse
    SteScouse Member
    560
    Liverpool
    Re gas i went with BOC but have hardly used any in the scheme of things so my first bottle will go into a second years rental
    Thats mostly down to having to weld outdoors and gas MIG vulnerable to wind
    Very nesrly got half of my garage set up now but its took me ages. So unless workspace indoors is available consider gas thats not on rental, likes of Hobbyweld
  15. Riot van Member
    19
    Bristol
    My machine is a Clarke 100 I'm not sure if it can be upgraded to gas but I will learn on it for now if I start doing lots of welding I will possibly upgrade to a more expensive gas welder.
    Also I'm doing this in my garage at home does one need special insurance or a lice se to have pressurised gas bottles?
  16. bourbon Member
    736
    Lichfield UK
    No licence is required for small amounts of gas
  17. gaz1
    10,705
    westyorkshire
    insurance might be an issue for the garage
    info for fire brigade is important inform them of the gas bottle if you have an issue
  18. jordan1 Member
    2,054
    Yorkshire England
    Try some Lincoln NR-211-MP.035 flux cored wire with a knurled 1.00 feed wheel, you will be amazed at the difference it makes. Gas is better but this is the next best thing to improve your welding.;)
  19. Country Joe Argoshield Dark
    1,521
    Somerset - United Kingdom
    He's quite right - it's top of the gas-less pile!
    CJ
  20. Ed B
    Ed B Member
    82
    Manchester
    As well as a fire extinguisher I have a fire blanket in my garage. Cheap as chips, does not go out of date and easier to use on small fires than messing around with the fire extinguisher
Advertisements
