Weld on stainless steel not staying on...
  1. SilentGuy Member
    16
    UK
    I've got a stainless steel tool that I want to modify by adding some small spherical tack welds. But when I weld it on using 0.6mm stainless steel wire 316, they come off pretty easily, as if I had welded onto copper.
    Does the base material need preheating? or could it be a different material than it claims?.
  2. Any chance of a photo
    gaz1 likes this.
  3. gaz1
    gaz1 Forum Supporter
    10,222
    westyorkshire
    it would help if you stated the material thickness you was welding
    the name of your machine and also what amperage your using
    no offense what you have posted is like searching in the dark for the answers to be given
    from that info i cant tell you nothing
    gordon stephenson likes this.
  4. Davidcardiff Member
    114
    Kildare . Ireland
    Material thickness
    Gas used
    Voltage
    Wire feed mpm
  5. SilentGuy Member
    16
    UK
    Material - Surgical stainless steel. Sanded it down because it looks chromish and it's got a slight gold colour.
    Thickness - it's not flat, but curved. But around 3mm. Not looking for deep penetration - just want to add a small circular blob around each side for grip and not attaching another metal to it.
    Machine - R-Tech Mig 180
    Voltage/Wire feed - Unsure, the amp readout isn't particular helpful since i can't read it under the hood. They're set to about 40% of max.
    Gas - 86% argon, 14% c02
  6. hotponyshoes Member
    2,372
    Somerset. Uk
    What tool is it?
    Is it ti rather than stainless?
    Davidcardiff and mtt.tr like this.
  7. Could well be martensitic which although weldable needs a lot more care to weld properly. You need to look at the filler wire plus pre and post weld heat treatment to avoid cracking, you’re also using the wrong gas which I won’t go into detail about as it’s a topic that seems to come up on a weekly basis and there’s loads of posts on here about
  8. 3mm will need more than 40%. I was welding 2mm today at 50% and that was only just penetrating.
  9. TechnicAl
    TechnicAl Member
    7,303
    Rotherham
    Richard. and backpurge like this.
  10. I know Al, just can’t help myself at times
Advertisements
