dan.taylor.1
General Tinkererer
- Kendal, Cumbria
Hi folks,
Changed to 1.0mm from 0.8mm today, swapped drive roll round, new 1.0/1 2mm liner, new 1.0mm tip.
Thw issue I'm having, is unless I use way more stickout than I normally do I get just hot wire nesting from the tip not a weld. When it does weld it's welding fine. I didn't get a pic as was pretty busy.
I've adjusted the voltage up and down about 24v and the wfs about 7/8 won't of 10, (not sure what the increments relate to) but it happens at any setting. As above, it seems to improve if I move the tip to say 20mm away from the work, where I'd normally have it as close as possible without dunking it!
Any help much appreciated as id rather not have to swap back to 0.8mm as I haven't any in at the moment.
Cheers,
Dan
Cheers,
Dan
