Kickmuck
- Manchester
Today i made a gate to reinforce my garage/workshop entrance door, but its all gone a bit pete tong.
I have managed to warp the frame.
Now i have learned from this and if i do it again it will be made a lot differently. I should have drilled holes into the box section and fed the round bar up and through and then tacked it all into place.
Instead i did it the silly way by cutting 12 individual pieces of round bar and welding them to the box frame. (i know dumbass me). You learn from your mistakes. if i lay it flat on the ground, two corners are up in the air a couple of centimeters.
Regardless of doing it all wrong my measurements were spot on and i tacked it all together before welding with filler.
Should i have clamped the frame down before welding the roundbar or was something else off? and how could i possibly un warp it? could i clamp it and leave it or maybe clamp it and heat it up or something?
Or is it now just scrap?
View media item 10667View media item 10668View media item 10669
