HughF
- Work: Dorchester, Workshop: Corfe Castle, Wife's place: Frome
I have a very nice harrison 600 milling machine that I run from a rotary phase converter... However I would like to convert it to a VFD.
I have a suitable VFD, a nice Optidrive E3 220-415 unit.
The mill has a nice multi-speed gearbox and a clutch/brake unit with continuous running motor. I'm after an opinion, would you:
1. Run the motor all the time through the VFD using the existing start/stop buttons and leave the clutch/brake alone.
2. Use the interlock microswitch on the clutch arm to start/stop the motor and clutch the spindle in/out.
The benefit of option 2 being that I can shut the motor down when not running the spindle and save noise/electricity etc...
I plan to use a 2nd VFD (which I also have) to run the power feed motor (I don't have the change gears for this so have a fixed speed presently) and use a capacitor on the coolant pump motor.
