Rig Pig
- Narrwich! U.K.
I have installed wet ufh in my extension at the wife's command, and with winter on the horizon it's time to start planning to get it working! The bit that concerns me is the floor is 60m2 and the boiler is 36KW so it's going to be trickling hot water through the mixing valve so I suspect it will be bouncing on and off when the main heating circuit isn't on. So I was wondering about fitting a small radiator in parallel with the manifold to allow a bit more flow and to provide a buffer for the heat, not as good as a heat store but cheaper and smaller - what do you think?
