Tin snips
  1. stuvy
    stuvy Member
    I’m after some new tins snips as mine have seen better days and are only cheap ones
    Any recommendations?
    Straight cut too please on ally and thin mild
  2. optima21 Forum Supporter
    2,483
    halifax, England
    Im using Wiss or Stanley fatmax offset avaiation snips for thin metal 0.9 or 1.2mm steel, the offset handles keep your hands out of the way if you're cutting deep into a panel. I already had the stanley snips but wiss are supposed to be better, but I cant say there is much difference, I think the stanleys need slightly less force to use and the wiss can cut slightly tighter radius. Im only working at home, but the professionals may say others are better.
    For 1.5mm steel I'll use gilbow snips then for thicker sizes I'll use something powered or a plasma cutter. some people will say they prefer gilbows and you can use them for 2.0mm and thicker. and say aviation snips are a waste of space.
    stuvy likes this.
  3. MCKDAVID Member
    Gilbows or Wiss.. no comparisons..
  4. AndersK Member
    537
    Sweden
    I use Wiss and a set of small Cocraft
    for aviation snips
    Bacho and some German brand for offset snips
    stuvy likes this.
  5. stuvy
    stuvy Member
    Will order a set on the gilbows
    Where I used to work there was a set of dewalt ones for opening metal banding straps. They were really bad for the money
    brightspark likes this.
  6. Pigeon_Droppings2 Member
    1,575
    london
    Best ones I have are an old pair of Gilbows I found on ebay....those aviation snips I find are a bit useless.
  7. MCKDAVID Member
    Just look in a sheet metal shop, and see what the tin bashers are using, almost certainly gilbows.... well all the ones I've been in anyway.. can't get a better recommendation than that..
  8. stuvy
    stuvy Member
    Most sheet metal shops Iv worked in they’ve all had them for donkeys years
  9. keithski122 Member
    828
    uk
    I've got snap on and midwest aviation shears, both work well.
  10. stuvy
    stuvy Member
    The Midwest ones are what I currently have
  11. premmington
    premmington Member
    960
    Norfolk
    I have loads of Gilbow ones (blue painted handles) A set of three Wiss ones - with rubber coated handles.
    One rouge Facom pair - really thin profile jaws - you can make long cuts with these and not bend the time too much.
    MCKDAVID, slim_boy_fat and stuvy like this.
  12. Burdekin
    Burdekin Chief Bodger
    4,522
    Aberdeen
    stuvy likes this.
  13. stuvy
    stuvy Member
    I did think about a bench mounted sheer but I wanted something to save picking a grinder up if I was just taking say a slither off of faffing at home in the shed
  14. premmington
    premmington Member
    960
    Norfolk
    I gave up with a rotary shear - they only cut 1.6mm
    I killed mine with slightly thicker stuff (2mm).
    Grinder will cut any sheet metal...
  15. Pigeon_Droppings2 Member
    1,575
    london
    For thicker stuff I have a bench cutter....that gets through most stuff especially if I hang off the handle!
    Best of all it came free on an old bench I bought years ago on fleabay....cant believe how lucky that was. I generally use it first and tidy up with hand shears....grinder is a last resort because of all the mess it makes!
    stuvy likes this.
  16. mechman Member
    1,607
    great britain n.e.lincs
    The guys offshore used Gilbow and Wiss.
    stuvy and Wallace like this.
  17. Wallace
    Wallace Member
    6,099
    Staines, Middlesex, England.
    The cheap chit Wiss aviation copies will do the job if you use them correctly as aviation snips one handed.
    Better quality real McCoy aviation snips will do the job longer, Gilbow’s are a different breed.
  18. stuvy
    stuvy Member
    What’s the difference, apart from being assisted in the aviation snips
  19. MCKDAVID Member
    Bench shears are handy theres no doubt, but can't replace snips, different applications with some crossover, even with a shear you'll still need snips.
    8ob likes this.
  20. daedalusminos Member
    563
    Norwich
Advertisements
