Thermal arc Lm300
  1. davidjohnperry a different breed
    2,172
    yate/bristol
    Hi guys question for the forum my LM 300 fan stopped working, was welding the other day with some 5mm 6010 and I caught a wif of hot electric smell the fan didn't kick in at all any ideals y the fan doesn't run plus the amps/volts display only works if you hold the preview button once let go shows zero values, cheers for help in advance also I think it's ok was a sanaex Machine
  2. 123hotchef Member
    9,498
    Kent
    I think you need to take the cover off and check does the fan constantly run normally? or does it kick in when it warms up?
  3. davidjohnperry a different breed
    2,172
    yate/bristol
    Think it should run constant
  4. 123hotchef Member
    9,498
    Kent
    might be that it has simply dies then should be a easy swap if it has
  5. Munkul
    Munkul Member
    2,137
    Cumbria, UK
    easy check for a multimeter...
    123hotchef likes this.
  6. davidjohnperry a different breed
    2,172
    yate/bristol
    How ??
  7. Munkul
    Munkul Member
    2,137
    Cumbria, UK
    take cover off, switch on, check voltage feed to the fan? It's basic diagnosis, you don't need the internet to tell you that.
  8. 123hotchef Member
    9,498
    Kent
    do you have a multi meter?
  9. davidjohnperry a different breed
    2,172
    yate/bristol
    Yes I do
  10. 123hotchef Member
    9,498
    Kent
    great get the cover off and check the fan is getting power first then
  11. davidjohnperry a different breed
    2,172
    yate/bristol
    Will do forgot to mention it's 3 phase
  12. 123hotchef Member
    9,498
    Kent
    should make no difference
  13. HughF
    HughF Member
    5,716
    Work: Dorchester, Workshop: Corfe Castle, Wife's place: Frome
    Probably a 24v fan mate, should be easy enough to check with the meter...
    davidjohnperry and 123hotchef like this.
  14. HughF
    HughF Member
    5,716
    Bump: need an owners manual for one of these in PDF format if anyone has one? Need the pinouts for the remote 14 and remote 17 sockets to make up some interconnects.
    The Victor website links are all broken/go straight to the esab na website nowadays :(
Advertisements
