Taylor lathe chucks
  1. spencer 427 Member
    6,925
    uk colchester
    Evening guys .
    Thought I would share the strip down and rebuild of a 8.5 inch Taylor lathe chuck . This is my second Taylor chuck .My other chuck being 5.5 inches and came with both sets of jaws. Unfortunately the 8.5 only came with the internal jaws. I will be serching for the other set. Taylor lathe chucks came in sizes from 4.5 inches up to 20 inches diameter. As you can see from the pictures below the chuck is great condition despite being full of swarf. It's had a light collision with a lathe tool but nothing serious. I also have a 10 page document showing all Taylor lathe chucks and accessories. 15405746522503629926971029313242.jpg 20181026_140612.jpg 20181026_140904.jpg 20181026_141919.jpg 20181026_141926.jpg 20181026_141934.jpg 20181026_142208.jpg 20181026_142212.jpg 20181026_142641.jpg 20181026_142654.jpg
  2. Richard.
    Richard. Forum Supporter
    18,350
    Cambridgeshire
    I hope you marked up where every part came from mate.
    spencer 427 likes this.
  3. spencer 427 Member
    6,925
    uk colchester
    I did indeed Richard. I always put a very small centre punch mark on both halfs . And I no the original locations for the internals. 20181026_141243.jpg
    Screwdriver and Richard. like this.
  4. Richard.
    18,350
    Cambridgeshire
    Top man. Thought that would be the case
  5. Pete.
    Pete. Member
    9,435
    Kent, UK
    Looks in about normal condition for a stripped 3-jaw. No obvious nasties in there.
    Do you have the outside jaws?
  6. spencer 427 Member
    6,925
    uk colchester
    Unfortunately not. I thought I had found a set. My jaws are D7. The set I thought I had found are J8.
  7. spencer 427 Member
    6,925
    uk colchester
    The chuck cases have cleaned up nice. All rust has been removed. Will give them a good sort out tomorrow. Jaws are in great condition. 20181026_173844.jpg 20181026_165435.jpg 20181026_164526.jpg
    decca and slim_boy_fat like this.
  8. Pete.
    Pete. Member
    9,435
    Kent, UK
    Always the way. I have two virtually brand new chucks missing the outside jaws. One set is not available the other is £25 more for the O/S jaws than I paid for the chuck.
    slim_boy_fat and spencer 427 like this.
  9. spencer 427 Member
    6,925
    uk colchester
    Yes mate. I will try and locate a set. I had a result with my other Taylor as it has both sets.
  10. slim_boy_fat
    slim_boy_fat Forum Supporter
    Bookmarked :thumbup:
  11. eLuSiVeMiTe
    eLuSiVeMiTe Member
    12,240
    Bedfordshire England
    Can't fathom these chucks. No perpendicular surface to set work too.
    Regularly use parallels to set work away from the chuck body but don't have the option with these.
  12. slim_boy_fat
    In some of @spencer 427's pics, the part near the hole looks as if it could be? :dontknow:
  13. eLuSiVeMiTe
    eLuSiVeMiTe Member
    12,240
    Nope dished all the way. Parms got one on his little John.
    slim_boy_fat likes this.
  14. spencer 427 Member
    6,925
    uk colchester
    Your correct. These are dished and you can't square off. I will have a selection of three and four jaws for it. They are very unusual chucks.
  15. spencer 427 Member
    6,925
    uk colchester
    I would like to find the 20 inch version .
  16. slim_boy_fat
    No need to be greedy. :D
    Dieselkid 63 and spencer 427 like this.
  17. spencer 427 Member
    6,925
    uk colchester
    I found a 10. No 20s yet.
  18. spencer 427 Member
    6,925
    uk colchester
    Both halfs have now had a good clean . Will put some life back in to the castings tomorrow. 20181028_190503.jpg
    Pete., Seadog and slim_boy_fat like this.
  19. spencer 427 Member
    6,925
    uk colchester
    My Taylor chuck is now complete. Pictures below are it's assembly. Straight forward enough. All moving parts are checked for movement and any problems are sorted. Everything is cleaned a couple of times and oiled. I use way oil for assembly as it's all I got until I find an alternative and it's better than grease. The chuck will not be used for a while as I need to make a backplate and finish the lathe refurbishing. I have new backplate bolts on order. The chuck is really nice now and very smooth in its operations. Taylor chucks were considered the best in there time but they did have a few problems. One problem is they are very heavy indeed and not recommend for small lathes. They are not everyone's cup of tea but I love them. 20181029_101223.jpg 20181029_111758.jpg 20181029_112818.jpg 20181029_115621.jpg 20181029_120111.jpg 20181029_120414.jpg 20181029_120625.jpg 20181029_121506.jpg 20181029_121552.jpg
  20. slim_boy_fat
    What's the finish you put on, oil or wax or something else?
Advertisements
