Superking Size Bed Frame
  1. Millentubby Member
    16
    Kirkliston, Scotland
    Hi folks,
    I discovered yesterday that my cheap divan bed base is knackered. I thought about bodging it (again) but I'd rather find a permanent solution.
    I have 50x50x3mm angle, 25x25x3mm angle and 25x25x2mm hollow square section and some flat/round bar.
    Drew this up on ProCreate on the iPad w/apple pencil last night (first time using- great bit of kit!) - anyone made something similar? If I use 50x50 angle for the perimeter of the top plane and 25x25 hollow square section for the rest will it be sturdy enough presuming 'normal' use (keep it clean! :whistle: )
    I've been told by my OH that I'd prefer something fairly high with room for storage boxes underneath and that can be easily vacuumed under.
    It will need to be carried upstairs so I think two separate sides that can be bolted together will do the job (red tabs on bottom pic are tabs for connecting).
    Each side will be 900mm wide x 2000mm (3'x6'6").
    [​IMG]
    [​IMG]
    Also, any ideas what it might cost to powdercoat?
    Cheers, MT.
  2. gaz_moose Member
    971
    tamworth staffordshire
    cost you more than just buying one
    slim_boy_fat likes this.
  3. Millentubby Member
    16
    The powder coating? Or the build?
    I have the metal stock lying about, and I'd hope to end up with a better quality product that will last much longer.
  4. armalites Member
    4,650
    Herefordshire
    I made all of the beds in my house but they are made of wood, they are all quite high but storage underneath is great. Made the first one probably 17 years a go and we still sleep on it every night. It doesn't creek/squeek or move at.
    It's very rewarding making something so important in your life, I think it will be more of a challenge to make one in metal that doesn't look too industrial unless that is a look that you like.
    Millentubby and slim_boy_fat like this.
  5. gaz1
    gaz1 Forum Supporter
    9,874
    westyorkshire
    ive adapted all my beds higher but they have been wood beds
    kingsize and bunk beds strengthened and highered on the sides matress sits higher on the frame so when getting out of bed your not pushing on your knees to get up
    the middle is strengthened by a post going down the middle and also a thickish single post in middle
    a word of warning once you strengthen the bed becomes solid compared to the divan
    your problem is when or if you move its the strip down and move the bed problem you will face
    Millentubby likes this.
  6. gaz1
    9,874
    westyorkshire
    on mine its 400mm high and matress sits inside of it by an 1" this allows people that are tall to have the matress higher than the knee
    its a wood frame and can fit 11" boxes underneath it for storage
  7. rtbcomp
    rtbcomp Moderator Staff Member
    18,615
    Sheffield UK
    I'd go for wood, it would be lighter for a start. I made mine 30 inches from the ground to the bottom of the mattress. It's much easier to get in and out of as @gaz1 says.
  8. gaz1
    9,874
    westyorkshire
    are you sure that its 30 inches high as that would mean its hip height?
    like a cabin bed
  9. rtbcomp
    18,615
    Sheffield UK
    ^^ Yup 30 inches, I did that deliberately because it's so much easier to get out of and I need the storage space underneath.
  10. armalites Member
    4,650
    Herefordshire
    I thought mine was high at 28" to the top of the matress but your's is going to be another 10" on top of that
  11. fizzy Forum Supporter
    5,606
    uk
    20160806_101049.jpg Here is my bed - excuse the mess!
    Cost me nothing at all - totally unbreakable - but weighs 363kg without the mattress!
    rockweasel and gaz1 like this.
  12. rtbcomp
    18,615
    Sheffield UK
    And if you die in your sleep they hoik you away on a forklift :(
    Wozzaaah, Millentubby and fizzy like this.
Advertisements
