cardiffrob
- Wales, Llantwit Major.
Strange request.
I have a 1 1/8 SU carb on an engine with a ported vac take-off where the butterfly sweeps over the port. This will give little vac until just off idle throttle position, I assume, whereas manifold vac will be the same figures except for high vac at idle. Now, if I have a drilling between the butterfly and the dashpot on the straight 1-inch section, does that have zero at idle and low figures all through the rev range with the exception of high vac when the throttle pedal gets suddenly depressed and before the dashpot has had a chance to rise? It will certainly never get as high a vac figure as the manifold.
I'm after finding the ideal spot for this Upper Cylinder Lubricant device (Redex Lubrocharger) from the 1950s that came with no instructions. Ideally I would have thought it only wants short shots of UCL whereas manifold vac would keep it drawing oil all the time? Not much internet info on this, unless I'm googling the wrong phrases?
I have the original Redex fluid here as well as some Marvel Mystery Oil, as used on aircraft engines for the same purpose.
It would be nice to be able to help keep this engine alive for as long as possible since spares are almost non-existant, unless someone knows where there is another for sale????
