Sources for 3 phase cable - 5 core 6A (0.75mm)
  1. puffernutter
    puffernutter Puffernutter
    1,149
    Wiltshire
    I need to add another feed in for a pillar drill.
    Where do you source your cable from. I need about 15m, but all I can find is 10m or 50m and I'd rather not join it, or have loads left!
    Cheers
    Peter
  2. eSCHEn
    eSCHEn Bit Wrangler
    5,514
    SW Scotland
  3. hotponyshoes Member
    1,115
    Somerset. Uk
    Is sy any use? Got a drum of it somewhere I can lop a bit off but I think it might be 1mm?
    brightspark likes this.
  4. brightspark
    brightspark Member
    26,339
    yarm
    hardly think 0,25mm will make any odds :laughing:
    Parm likes this.
  5. Ton-up
    Ton-up Member
    1,303
    Essex, England.
    Our local supplier (Tec Supplies) cuts what you want, might be worth ringing round.
  6. 500e
    500e Always buy fire insurance a flood is hard to start
    3,801
    Somerset UK
    Most good wholesalers will cut SWA to length
    Parm, eLuSiVeMiTe and brightspark like this.
  7. MCKDAVID Member
    got tons of solid core 5G 1.5mm² and 2.5mm² sat here doing nothing, run the feed in, and JB at the end then onto flex to the drill...if that's any good to you, pm me an address and I'll throw some over...
  8. puffernutter
    1,149
    Wiltshire
    I'm ignorant - sy? It will be run internal to my workshop, so if that's suitable yes please!
    Cheers
    Peter
  9. HughF
    HughF Member
    5,298
    Work: Dorchester, Workshop: Corfe Castle, Wife's place: Frome
    Sy will be perfect, just p clip it to the wall/timbers/whatever... it’s the pvc, galvanised braid, clear pvc stuff.
    If you can settle for yy, I’ve got masses of 5x.75 at work
    zx9 likes this.
  10. zzr1200
    zzr1200 Working at 650 ft on open steel work
    3,484
    Brimington, Chesterfield, Derbyshire
    TLC direct ...... will cut to length
    eLuSiVeMiTe likes this.
  11. puffernutter
    1,149
    Wiltshire
    All, thank you. As ever I have learned a lot from this forum.
    @hotponyshoes, when is it convenient to pop over. Looks like I owe you a few beers...
    Cheers
    Peter
  12. heldtogetherwithblutack
    heldtogetherwithblutack Member
    67
    Newton Solney
    please read this before making a decision on using SY (or YY, or CY)
    https://www.whyprysmian.co.uk/sy-yy-cy-cable.html
    BASEC is looking to create standards for these types of cable, I'm not up to speed on this and have no idea how far they've got.
    https://www.basec.org.uk/news/2018/...ut-on-a-new-specification-for-control-cables/
    There are literally thousands of google hits on the subject of it's use, you can see it everywhere in commercial and domestic installations, however,
    All I'm saying is, until it's ratified, if ever, I wouldn't entertain the idea of specifying as it could possibly entail a liability claim.
    mymini86, MetalMonkey and mtt.tr like this.
  13. Munkul Member
    555
    Cumbria, UK
    I used to use SWA but now just use SY for most things on the farm. They use SY everywhere at work in cable trays and surface mounted stuff. It's much nicer to route and terminate than SWA, glands are cheaper and more foolproof to install.
    City Electrical Factors is usually where we go, they will do cut lengths no problem so you don't have to buy a full drum.
  14. HughF
    HughF Member
    5,298
    No-one is talking about specifying it, we're talking about someone buying some cable to wire up an outlet from their RPC to a new tool in their workshop... There is no liability involved
    daleyd likes this.
  15. hotponyshoes Member
    1,115
    Somerset. Uk
    Just had a look and the SY is 1.5mm
    Other option is some ho5v2v2-f (heat resistant white flex) in 0.75mm
    Either of those any good?
    @puffernutter
  16. MCKDAVID Member
    you can use any size as long as it's bigger (within reason) than original, come up to a JB jut before the drill and connect down to the 0.75mm² there, if it's around 15 metres from source you'd be better off with bigger anyway, potentially less volts drop...
  17. puffernutter
    1,149
    Wiltshire
  18. hotponyshoes Member
    1,115
    Somerset. Uk
    @puffernutter it's in the van with me at the moment, I can drop it at my place late morning if you are in a hurry for it otherwise I will be home about 6:30ish ?
  19. puffernutter
    1,149
    Wiltshire
    Sorry, in London today. Are you around tomorrow night?
    Cheers
    Peter
  20. hotponyshoes Member
    1,115
    Somerset. Uk
    Yea I'm around tomorrow after 6 .
    Only thing is the A361 is closed from 6pm-7am at the moment so either take your chance on getting through (they seem to be randomly working on it) or come in via the corsley road.
    I will leave it outside the back door in a bag so if you want to come over earlier and help yourself just watch the gate as the post is a bit broken and the dogs might be outside!
Advertisements
