I bought an aldi air regulator filter/lube and lines a few weeks back. How do i set it up??
do i take off the stock regulator pictured below or do i take out the bung in the tank and plumb it from there??
Yep i got those PCL's with the aldi hoses etc. I think i'll just connect it straight off the stock reg instead of the tank bung. Thanks for the help.....
The ones I got with my Aldi reg were Italian ones, not PCL pattern.
The bung should be RH thread. It is probably held in place with a pipe sealer. Get it hot (too hot to touch, not red hot!) and it should turn easily. Make sure all the air is drained from the tank or you'll have a bullet shooting out at you.
