Semco cnc mill problem
  1. scottmk1
    scottmk1 Forum Supporter
    1,257
    Scotland
    I have a Semco CNC bed mill, it has had a GSK 983 controller fitted but still uses the Anilam servo drives and boards. The wiring looks like a mess unfortunately, should have checked that before I bought it but there you go.
    Anyway recently I fired it up and get alarms about the Z axis detecting device pulse encoder, and the Z axis motor is constantly turning. See the alarm below:
    Where do I start with trouble shooting this?
    Here is the cabinet on the back of the column:
  2. skotl
    skotl Forum Supporter
    6,757
    Edinburgh, UK
    Do you have an oscilloscope, or a frequency mode on your multimeter, that you could use to see whether you're getting pulses from the encoder?
    Also - is it possible to swap the pugs for the Z axis encoder with one of the other encoders and see whether the problem stays on Z or moves to the other axis? That would confirm whether you have a problem with the encoder and its wiring or on the board.
    Parm, Hopefuldave, Seadog and 2 others like this.
  3. Hood
    Hood Forum Supporter
    10,309
    Carnoustie, Scotland
    First step is look at the encoder on the motor (or ballscrew) and check all looks ok.
    Not sure if it is a Step/Dir control or not, if it is then the encoders will almost certainly go to the servo drives, if not then they will go direct to the control, trace the wire and check all is ok.
    If you have a scope you could check the signals when they enter the drive/control.
    Hopefuldave likes this.
  4. Hood
    10,309
    Looking at the pic there doesn't seem to be much in the way of connections to the servo drives so I am more inclined to think it is analogue command and the encoders will go direct to the control.
    pressbrake1 likes this.
  5. scottmk1
    1,257
    Scotland
    I don't have a scope unfortunately, but I will check my meter and see what it can do.
    Currently swapping the boards over and it's apparent that the Z axis one has been out before!
    skotl likes this.
  6. Hood
    10,309
    Often just cleaning the contacts can help.
    scottmk1 and skotl like this.
  7. scottmk1
    1,257
    Scotland
    OK so the fault doesn't transfer with the board so I've whipped the servo motor off and I'll check the contacts. DSC_0805.JPG
  8. Hood
    10,309
    Motor looks like it may not have an encoder, no mention of it on the data plate. Check to see if there is an encoder on the ballscrew.
  9. scottmk1
    1,257
    Scotland
    OK will do. There's no obvious sign of one so I assumed it was integrated into the motor.
  10. Hood
    10,309
    It may be as I have just looked at the SEM manual and the end cap on yours does look to be extended more than the one in the manual.
    scottmk1 likes this.
  11. scottmk1
    1,257
    Scotland
    Well I can't see anything on the ballscrew the X axis motor does have an extra bit on the end though?
  12. Hood
    10,309
    Have a look in your control manual and see where the encoder inputs are. Trace them back and they will go to the encoder or servo drive. The pic of the servo drive makes them look like they are analogue amplifiers as there are not a lot of wires going to them so I am guessing the encoders will go direct to the control.
  13. scottmk1
    1,257
    Scotland
    Well I'm guessing this is the bugger?
  14. Hood
    10,309
    Yep, Renco encoder, maybe even info there in the lid as to what colour is what.
  15. Johnnybravo Member
    927
    Northiam
    First thing I would do would be take the brushes out the servo motor and blow all the carbon dust out. Encoder cannot do its job if commutator is clogged up with dust,as it will over shoot the mark constantly. Something I learnt from the Prototrak mill....
    Hopefuldave and scottmk1 like this.
  16. scottmk1
    1,257
    Scotland
    OK so I found a loose wire in the control panel, along with a couple of pikey connections. Sorted that and it's still the same.
    Back home now to have a look at the manual
    WorkshopChris likes this.
  17. scottmk1
    1,257
    Scotland
    Thanks I'll try that later
  18. scottmk1
    1,257
    Scotland
    OK, took the brushes out and blown it out with the air gun, it seemed to make an improvement for 10 minutes then went back to the way it was. The brushes are fairly worn, so I'll change them, also got the manual here so I'll get familiar with the wiring diagram!
    skotl, Woody.v8 and mike os like this.
  19. scottmk1
    1,257
    Scotland
    OK here is wiring diagram inside the motor, I've traced all the wiring for it back to the source, here is the diagram:
    So from the encoder, the red and black wires each split into two with red and black going to a multi plug for the X axis and Y axis.
    The white, green and brown all go to this device:
    From that device all wires go to the Z axis port on the back of the control panel.
    The two small red and black wires from the motor go to the Anilam card for the Z axis, as do the heavy wires, and finally the ground obviously goes to the ground point in the cabinet.
  20. scottmk1
    1,257
    Scotland
    I've cleaned the crap out from in between the commutator segments on the Z axis motor and put it all back together, it's now running even faster than before, when it should be stationary! Maybe the commutator is goosed? How can I test the encoder with a multi meter if at all?
Advertisements
