Security Lights on house - what wire?
  1. T.E.D. Jordan Member
    63
    UK -Cumbria
    I'm replacing a 600watt security light on the outside of the house with a 400watt light and adding another around the corner of the house, meaning I'll have to run a cable around 6/7m round the corner.
    I plan to replace the existing one and just branch off that for the next one, but don't know what cable to use and how best to attach it to the wall (brick and mortar.
    Any suggestions?
    Jordan
  2. superls Member
    252
    uk, chesterfield
    id just use 1mm twin and earth and cable clip it to the wall
  3. madkayaker
    madkayaker Pro sparkey Pro Welder
    13,694
    Cumbria
    T&E cable is the way its been done for years (to god effect) however for outdoor use the UV degrades the insulation and water can get in and start being a pain. i would recommend using a flex type cable with rubber being best.
    I would also se LED lights to save a packet in power usage!
  4. brightspark
    brightspark Member
    30,672
    yarm stockton on tees
    flexible cable shouldnt be used for fixed wiring over a distance apart from a short tail from a waterproof box to the light fitting. by rights it could be wired in grey twin and earth in a conduit or armoured cable . both look a mess on a private house :(wiring it in flat grey clipped looks the neatest but isnt uv stable but would last donkeys years anyway .
  5. madkayaker
    13,694
    Cumbria
    the distance allowed is 10m.
  6. Robotstar5
    Robotstar5 Casanunda Staff Member
    18,169
    Birmingham
    I normally use FP200 for outside lights.
  7. wheresmejumper
    wheresmejumper Banned
    2,630
    Cork
    why not NYMJ?
  8. Premiershipman
    Premiershipman Member
    870
    Isle of Man
    What about SY multiflex cable?
  9. T.E.D. Jordan Member
    63
    UK -Cumbria
    Argh!!! These terms are confusing me!
    So 1mm twin and earth should be up to the task, just that the UV de-grades the wire over time...
    Whats the best solution for glipping it to the brick/mortar wall? I've used little rawl plugs internally with normal 'beam clips' in my workshop, is that the best option?
    Jordan
  10. madkayaker
    13,694
    Cumbria
    You can get fibre plugs for your clips to nail into there normally grey DIY shop normally have them
  11. brightspark
    brightspark Member
    30,672
    if u use decent clips they should go in the mortar if its not like concrete. if its soft and clips fall out or either just shape some wooden plugs and hammer them in and snap em off ;)
  12. superls Member
    252
    uk, chesterfield
    RE the UV issue on T&E weve had some T&E on the outside of my dads house for 20 years and its still ok to this day
  13. madkayaker
    13,694
    Cumbria
    As I said that's how it has been done for years but the regs draw attention to the uv issue
  14. wheresmejumper
    2,630
    Cork
    thats why people use NYMJ
    its is physically tougher
  15. Robotstar5
    18,169
    Birmingham
    Been a sparky for 35 years and I had to look up NYMJ :ashamed: :laughing:
  16. sparky_col Member
    140
    Gods own country
    same here.
  17. wheresmejumper
    2,630
    Cork
    its a very tough cable,performs and costs somewhere between pvc/pvc and armoured.
    easy to clip in neat runs,harder for rats to chew through.very common here for external walls,and surface garage installs
Advertisements
