fasteddie84
New Member
- Jersey
Hi all
Went to use the welder tonight and only the fan works, nothing else! I recall turning it off the other night and hearing a crack but didn't do anything about it so think something has blown.
Taken it apart and tried all the tests with basic tools.
The fan works and the gas works but nothing else. Tried manually feeding the wire out and arcing it to the earth cable and nothing. Tried putting power to the feed motor (a 6v battery) and it just about moves with that. There is no click when you press the button. All fuses (plug and PCB) are good. No disconnected wires or burnt out modules.
I was a bit stuck but decided to manually activate the relay on the PCB and it works which leads be to think the PCB is at fault. Anyone agree?
Thanks
Thanks
