Kram
- Sussex
Replaced worn out disc with a used, "new" one. It is bent, probably by a disc lock. 1.6mm of runout. Spec max runout is 0.2mm. it appears simple, the low is exactly opposite the high, as if it was mounted badly.
As it is a floating disc (alu hub, bobbins and steel outer) it can move but still creates excess heat.
Considering the idea, bolting the disc to vertical slide by the outer, and flycutting the hub face flat, problem is the bobbins would allow it to move. How can I set this up?
