So I've started cutting out the rot from my Ford Galaxy today.
The first repair is the box section outrigger / jacking point.
Before i plate over I need to treat the surface rust on the areas that are not being replaced.
What would you lot recommend?
I was thinking some sort of rust neutralisor then weld through primer and final waxoyl cavity spray once welded.
