Roof repair cost
  1. winchman
    winchman Member
    2,305
    Merseyside
    Terraced house replace bottom 1 metre of felt and battons, re point ridge clean moss off, what should I pay?
    House is about 22ft wide
  2. angellonewolf
    angellonewolf Member
    3,264
    bristol england
    roofman likes this.
  3. julianf
    julianf Member
    3,461
    devon, uk
    I don't have an answer for you, but you should also indicate if it's tile or slate, and it they can be reused, and also if the enevitable replacements are easy to find.
  4. julianf
    julianf Member
    3,461
    devon, uk
    Also, easy access for scaffold? Skip needed?
    Ie you need to give a load more info.
    slim_boy_fat likes this.
  5. roofman
    roofman "Hey!! calm down calm down"
    5,640
    North West
    slate or tiles...front,back or both...whats the access like for scaffolding stage at gutter height. sometimes its much better to dry ridge it rather than re-point over old mortar. Sorry to sound a smart ar$e but everything i have mentioned effects price;)
  6. winchman
    winchman Member
    2,305
    Merseyside
    Front and back tiles built in 60's.
    Access to back is down a small alley way between houses.
  7. roofman
    5,640
    North West
    £1200-£1400
    mike os likes this.
  8. Cobbler
    Cobbler Codger bodger
    3,920
    Gloucestershire UK
    I hate to hijack a post, but seeing as we are discussing roofs, I am having a flat roof looked at tomorrow with regards to refelting. Mr Roofman, which do you advise, old fashioned felt or the inflatable boat type material, EDPM is it?
  9. mike os
    mike os just a little insane.....
    5,513
    North Wales
    About 100 to 120 a meter would be my guess
  10. mike os
    5,513
    North Wales
  11. angellonewolf
    3,264
    bristol england
    fiberglass ?
  12. eLuSiVeMiTe
    eLuSiVeMiTe Grumpy Youngish man.
    4,848
    Bedfordshire England
    Felt for me. Can't stand edpm
    roofman likes this.
  13. Cobbler
    3,920
    Gloucestershire UK
    What's wrong with it?
    The existing felt roof was done 20 years ago when we moved in & the main part is still ok, only the bits over the arris rail at the edge & where it's tucked under the tiles is bad. The main roof was covered in some sort of silver paint to stop uv damage I think & it as good as the day it was done, but from what I recall the edges had to have green mineral felt on. I'll see what the roofer says tomorrow, it may not be needed to replace all of it.
  14. eLuSiVeMiTe
    4,848
    If it isn't done well it won't last. Lots of people bodging it in.
    If I had a freestanding building I'd consider it. Anything complex and felt would be my preference.
    Weak points being against existing buildings/up stands and windows.
    roofman likes this.
  15. Cobbler
    3,920
    Gloucestershire UK
    That makes sense, it is a fairly complex shape.
  16. winchman
    winchman Member
    2,305
    Merseyside
    Thanks
    Offered mates rates at £450 cash, good friend of a friend so I should take his hand off?
    Parm and bigegg like this.
  17. angellonewolf
    3,264
    bristol england
    as long as you help to see if hes donig it ok
    bigegg likes this.
  18. roofman
    5,640
    North West
    yes mate and when he is done tell him roofman off the internet has a full book of work for him here:thumbup:
  19. roofman
    5,640
    North West
    I have stopped doing rubber for various reasons and now offer the following
    18mm plywood decking
    Vapor escape layer (hundreds of holes in felt to disperse moisture across roof area to stop blisters in localized areas)
    full SBS 2mm base layer
    full SBS 4mm intermediate layer
    full SBS 4mm mineral surfaced cap sheet..black,brown,white,blue,brindle,green are your main colour choices
    roof life in excess of 40 years and will cost approx £75 per sq meter fully inclusive;)
    eLuSiVeMiTe and slim_boy_fat like this.
  20. Cobbler
    3,920
    Gloucestershire UK
    Thanks for that, Roofman, that sounds like that's what the guy wants to use, he won't use rubber for a variety of reasons. He tells me a life of 40 years, at 69 I don't think I need to worry too much :laughing:
    roofman and slim_boy_fat like this.
Advertisements
