Removing water from air
  1. KSE39M5 New Member
    13
    Lancashire, UK
    Personally i have a regulator with water trap after the main compressor, this feeds into an air drying water trap () which works very well, then into a secondary 100 ltr air receiver. After this i go into a 3 stage filter, then i have a water trap on my gun.
    Seadog likes this.
  2. brightspark
    brightspark Member
    27,599
    yarm
    I have a separator on the main tank and a secondary tank near the end of the line then another filter then out to the gun or tool the second tank can handle the water even after blasting using a large air flow of 28cfm :)
  3. 8ob
    8ob Forum Supporter
    4,635
    moscow on thames
    Buy a decent workshop heater or bring the whole lot to the Sarf to spray it :)
    [​IMG]
    500e likes this.
  4. I have a workshop heater.On another note i notice u pol do 2 different speeds of pannel wipe, should i be using the fast or slow?
    Edit, i went for slow as i will have more time to wipe off.
  5. delta9 Member
    253
    UK
    I use fast for everything.
    They use slow on larger panels, but you can use fast on large panels by degreasing it in smaller sections.
  6. Just thought that as im doing a whole bumper and a bonnet id be as well with slow.
  7. Was looking at a kit with 2x10m hoses with the water trap in the middle, i have 2 hoses, 1x1/4 and 1x1/2.So am i right in thinking 1/2 to water trap then 1/4 to gun with inline filter at the gun?
  8. Yamhon likes this.
  9. brightspark
    brightspark Member
    27,599
    yarm
  10. Not much else i can do, for all ill use it i cant really justify spending a fortune.Wont there be less moisture on a hot day anyway or am i mistaken.
  11. Yamhon Member
    961
    Earth
    Isn't there a cheap way the pipes could be cooled without introducing other problems. Maybe something as simple as a shower head over the top of the pipes connected to a water catch basin underneath with a few froze ice blocks and a pump.
    Or insulation, etc...
  12. gaz_moose Member
    954
    tamworth staffordshire
    blow a fan on them in the summer????????
  13. premmington
    premmington Member
    1,397
    Norfolk
  14. brightspark
    brightspark Member
    27,599
    yarm
    cooling fan would work over the pipes I just use a secondary tank near the end of the line just sat on the floor then a second water separator
  15. Seadog
    Seadog Forum Supporter
    4,779
    NE London - UK
    There's a lot more moisture in the air when it's hot. The least humid days are cold crips days, typical November weather.
    Yamhon likes this.
  16. gaz1
    gaz1 Forum Supporter
    9,082
    westyorkshire
    sort of a silly thing but anyone been to barbeques and had those water butts with all those bear cans in it
    remember how cold your bear :D was when you pulled your can out :drunk:
    so think about it for use when in summer just drain it in winter
  17. Seadog
    4,779
    NE London - UK
Advertisements
