dai welsh and proud Messages 742 Jul 19, 2019 #1 When welding you need to disconnect the battery to avoid surges,is it the same with plasma cutting?
johnik Member Messages 724 Location sunny Somerset Jul 19, 2019 #2 i would play safe and disconnect it, i know people say it wont blow an alternator / ecu but i have blown an alternator and know people who have fried ecu,s , better safe than sorry
Lazurus Member Messages 1,086 Location Norfolk uk Jul 19, 2019 #3 Get one of them battery saver thingies that plug in to keep radio codes and the like alive when battery disconected.
zzr1200 Working at 650 ft on open steel work. Messages 5,428 Location Glapwell, Chesterfield, Derbyshire, UK Jul 19, 2019 #4 I use a surge protector that is clamped across/on to the battery terminals. Even when I'm using hf ac tig, welding aluminium cages or booms, not had a problem with an ecu. Just make sure the return cable is close to the welding area...
grim_d Unlikeable idiot. Messages 4,218 Location Scotland - Ayrshire Jul 19, 2019 #5 IMO it's quite simple. Electricity takes the path of least resistance. If your return clamp is situated right next to the area you are working it can only go down that. Don't clamp your return onto the negative battery post. If you are worried use a surge protector as above.
