9CFM in litres pour minutes are roughly 100?Depends on the cutter I have the R Tech 30 and runs fine on an 9CFM
Finally I've got the time to check your link
No pilot arcwhat's wrong with a PT31?
Yes I knowYou'll need a pilot arc machine to use a pilot arc torch.
The main issue I have is that I have 16A service so 3.3kWAir consumption on the hobby plasma cutters is generally low, you'll probably have to stop cutting due to overheat on the plasma before air becomes a problem on a hobby 2-3kw compressor.
Yep that's one issue ,for this reason I would like to find the best compromise betweenI doubt that a 1.5 kW compressor is big enough.
