Peened in universal joint.
  1. The UJ on my propshaft is a bit notchy, its got 165,000 miles on it. Unfortunately it's peened in, no circlip. Has anyone had any success in swapping one like this out?
  2. Ruffian Member
    1,358
    Devon UK
    What vehicle is it on?
  3. 123hotchef Member
    6,294
    Kent
    some have internal circlips
  4. It's off my 1979 450SL.
    You can see from the picture it is peened in, no circlip.
    [​IMG]
  5. 123hotchef Member
    6,294
    Kent
    some have them internally
  6. 123hotchef Member
    6,294
    Kent
    but that looks like it has 8 or 9 splines might hammer out with a good punch
  7. dan treg Member
    151
    uk midlands
    i used to work for gkn driveshafts its a staked joint done with a press. can be redone but preferably by re staking with a press
  8. hotponyshoes Member
    790
    Somerset. Uk
    Yea you can grind out the notches with a dremel and then stick them back in with a chisel afterwards.
    Although the last one I took apart I could not find the correct bearings for it so it went to the scrap.
    You will probably have to make a former to beat the bearing caps back into shape as well as they tend to distort as they need pressing out. (Unless you can find a bushing the right size to press them out with maybe)
    RaceDiagnostics and 123hotchef like this.
  9. Cobbler
    Cobbler Codger bodger
    4,106
    Gloucestershire UK
    There used to be a kit to change them, Moprod I think. A broach to restake them & a measuring thing to make sure the they were in the right place. I borrowed a mates one years ago, but don't know if they are still available. The joint cups on some of them were different sizes if I recall.
    Edit. The kit included a joint, but spares used to be available. It was very much a do it your self kit from the car parts shop, not the motor factors.
    colnerov and RaceDiagnostics like this.
  10. andymfell Member
    115
    cumbria uk
    find a local propshaft specialist easier and probably reasonably priced there are a couple with FK postcodes
    I used to work in a garage years ago I used one of the tools to replace a UJ on a morris marina estate the tool was used in a vice to push the new cups in and stake the bores, customer wern't very happy when it failed a relatively short time afterwards when on the motorway
  11. I'll pop into East Coast Props as it's only 5 miles away and see what they say.
    CompoSimmonite likes this.
  12. ibrooks Member
    916
    UK Lancashire
    RaceDiagnostics likes this.
  13. Robotstar5
    Robotstar5 Casanunda Staff Member
    17,372
    Birmingham
    I installed a few handling robots there when I worked for ABB.
  14. frank horton
    frank horton V twins are great but 4"s rule.........
    1,147
    manchester, UK
    easy peasy to repair.......cut the cross out, drive the cup bearing inwards to remove......if u can use a rotary flap wheel to remove most of the swagging marks, obviously dont make the bore any bigger.....I usually start with a fine 1/2 round file....
    ONLY TAKING THE LIP OUT.....I'm lucky enough to have an adjustable reamer but really not necc. JUST TAKE UR TIME......it's not a race.......
    anyway once cleaned and smooth push the new joint in in the normal way,,,,, GET IT CENTRAL then take a thick washer 3mm etc drop it in the hole......(I usually turn me own to suit)....
    so 3 good blobs with a stick welder / MIG on the edge will fix the joint......easy to clean off and redo the joint in later years......
    I have done 100's and never had a failure.......my old Volvo did 350,000mile with 1 repaired as above before I scrapped the car......
  15. seriesonewelder Member
    285
    West Midlands
    Aldridge?
  16. Last edited: Aug 10, 2018
    slim_boy_fat likes this.
  17. 500e
    500e Always buy fire insurance a flood is hard to start
    3,554
    Somerset UK
    I have a Steak bearing tool Moprod PJK1 in box
    Cup size is 1.243Th
    What size are you looking for the actual joint was used long ago 7 the re staking tool was a throw away but easily made on a lathe
  18. The UJ is 24mm x 74.4mm but If I was to fit a new one I would just go for the welded washer solution.
  19. Cobbler
    4,106
    Gloucestershire UK
    From what I recall, the staking tool I used had been used several times, might not of meant to be though
  20. armalites Member
    3,473
    Herefordshire
Advertisements
