Damaged I blame the penguins. Messages 393 Oct 30, 2010 #1 Hi all, I know I can't braze with Oxy / Propane but can I weld with it? If so what sort of filler should I be using? Cheers, Mick.
brightspark Member Messages 39,188 Location yarm stockton on tees Oct 30, 2010 #2 Damaged said: Hi all, I know I can't braze with Oxy / Propane but can I weld with it? If so what sort of filler should I be using? Cheers, Mick. Click to expand... its the other way round u cant weld with it but u can braze
mike os just a little insane..... Messages 9,810 Location North Wales Oct 30, 2010 #3 not hot enough.... maybe for thin sheet? but just as easy to braze then because joint strenght is not a real issue
pedrobedro Man at Matalan Messages 12,736 Location CX near Chesterfield Oct 31, 2010 #4 Oxy propane turns steel into aero bars and wouldn't weld even thin metal. The flame is totally wrong for welding.
