Overhead welding on sill
  1. bengyb Member
    17
    West Sussex UK
    I'm about to start welding an inner sill / floor pan and it requires some overhead welding.
    I'm not keen on running a bead, is it ok to stitch?
    I've used the same technique on over areas I've patched already to avoid panel distortion.
  2. frank horton
    frank horton V twins are great but 4"s rule.........
    1,961
    Soon 2 B Crete
    don't know if it's the aceptable way for MOT's any more.......too long outta the game but I stitch everything....even now...with the odd fiull bead at the joint ends.........
    no better, no worse than the spot welds from the factory........but they do start with clean metal........but had a few new car panels that wern't spot welded prop from the factory.......
    but from the outside who can tell........
  3. Shoggi
    Shoggi Member
    217
    Bradford west yorkshire
    I was told they only check the welding
    If they have failed that part of the metal on the car
  4. Kent
    Kent Member
    10,002
    Bowland, Lanacshire,UK
    Stitches are just full welds that ain't joined in rusty crusty car terms.
    I would not genrally expect to put in a long continuous bead overhead from the get go on most old car tin. But it would end up continuous
  5. fixerupper
    fixerupper Member
    1,623
    Crete Greece
    Isn't the "thin metal technique" the best way to do this overhead anyway ...
  6. addjunkie
    addjunkie Member
    6,034
    Northumberland. Reet oot in the sticks
    Id do the same continous joined up big tacks.
    But I dont weld cars, i hate welding cars, Id suggest getting some one else to do it. But thats not constructive advice.
    owas likes this.
  7. spencer 427 Member
    6,925
    uk colchester
    Continuous joined up big tacks are fine. I just recently welded up the rear end of a camper van. Outriggers. Rear sills and a load of other bits. It passed it's mot. Even got offered a job from the garage that done the MOT. Downside is I totally detest car repair welding. Only done the job as it was good cash and used all the guys welding equipment and four post ramp
    Ruffian likes this.
  8. aguycalledsteve
    aguycalledsteve Member
    526
    Mansfield
    I sense a landrover somewhere in that :laughing:
  9. Kent
    Kent Member
    10,002
    By comparison to many Land rover are easy. Sure they often need a lot but that's the use and age as much as anything
  10. Shedendman
    Shedendman Member
    4,343
    east sussex
    As @spencer 427 said short tacks in a continous line its not easy getting long beads overhead on tin
    I stich all the time my MOT guy i work for is happy with it
    Check the tutorial in the mig section for thin metal
    Little tip grind the shroud nozzel back till its level with the tip use a tadge more stick out up your gas just a little more
    ;)its a tack wait tack wait tack wait joined up,do an inch then move to another part of the panel,same there move round untill your all done,practice,it'll come
    spencer 427 likes this.
  11. Burdekin
    Burdekin Chief Bodger
    5,127
    Aberdeen
    Normally floors are spot welded to the inner sill, can you plug weld the floor to the sill, that would be acceptable if the floor was previously spot welded. Any pics?
  12. aguycalledsteve
    526
    Mansfield
    I done quite a bit to mine this year and whilst I thought at the time it was difficult. It's a walk in the park in terms of fabrication and access compared to what others have got up on here with their project repairs.
    Kent likes this.
  13. addjunkie
    addjunkie Member
    6,034
    No it
    I havent been a land rover owner yet, though thinking about it. Ive welded a few, though, not to bad to be honest. Worst I ever tried was a 2cv, but t was mainly minis and escorts in my younger days.
    If its up high and access is good its not so bad, but lying on your back, on axle stands no thanks.
Advertisements
