RonA
specialist in repairing sealed for life equipment
- Stockton on Tees, UK
Ive posted before about problems with my Discovery sport tow electrics, basically the module which allowed trailers with LED or conventional bulbs to be connected to the vehicle went faulty & the vehicle system thought the trailer was still connected. This stopped the rear parking sensors working.
This was rectified by the purchase of a new module, which temporarily cured the fault at a cost of further £25 but after. recent caravan trip & the fault came back.
After another call to the tow electrics supplier, found out the no longer sell my electrics & the only way forward was to purchase another make of electrics (German made) at a cost of £91 (ouch). Complained bitterly & the firm finally agreed to take off the cost of the second module purchased bringing the price to £66. Again the new system was supposed to handle LED & conventional lighting.
New kit arrived, I have fitted it & it works (for now). After fitting I tested the operation with my Sealey tow (MOT approved) plug tester but noted the indicator lights on the tester (LED) flashed fleetingly. Then I connected a tow board (bulbs) & it all worked perfectly.
On reading the fine print on the new kit instructions it states it will work with conventional bulbs & “weighted” LED’s (presumably with a resistor).
To my mind the kit is not compatible with LED lighting as a “weighted” LED is effectively electrically the same a conventional bulb. The original electrics module worked ok with my Sealey tester ok & presumably with unweighted LED lighting.
Opinions please before I get back onto the supplier.
RonA
RonA
