Hi guys. Im still giving the wishbone mounts some thought....
On a different topic...
I need to chop the bottom off the mild steel sump to give me a bit more road clearence on the kit car.
I plan on MIG welding a mild steel plate on the bottom and making a small box on the side to retain the origional oil volume.
My question is; Is it possible and relatively easy to get good weld that will not leak under heat/pressure? or would I be better tac welding it with the MIG and then getting someone with a stick ARC welder to fill in the joins?
Dunc
Dunc
