Clarke 90 or 151. https://www.machinemart.co.uk/p/pro-90-mig-welder/
The old blue models are unchanged after 30 odd years; they just work better and for longer, than the others.
Used ones (I've found, with more than ten off) are as good as new, with £10 to £20 spent servicing the worn out parts.
Yep I was looking at the 151 but it needs a 30amp plug
Right at the top end the 151 may blow a 13 amp fuse but otherwise a standard 3-pin 13 amp fused plug will be fine. Examples:
https://www.mig-welding.co.uk/forum/threads/clarke-151en-help.17270/
https://www.mig-welding.co.uk/forum/threads/clarke-151te-plug.70702/
Thanks for the info. It looks like the 151 is the way to go.
Do you know if it has a non-live torch ?
Thanks again
