MT3 Collet Chuck
  1. Brad93
    Brad93 M J B Engineering
    6,594
    Essex
    Seems Cutwel have none available in ER32.
    60 day plus wait.
    Want it for the lathe so I can put taps in the tailstock and parts in the spindle taper.
    Is ER32 the best option?
  2. MattH
    MattH Member
    3,651
    Bristol
    I tend to put taps in a drill chuck (preferably a keyless) which will allow the tap to spin instead of snapping.
    I'd also use either a faceplate with ER collets or a proper lathe collet system in the taper i.e. 5C so that you can pass longer stock through it.
    addjunkie, Brad93 and pressbrake1 like this.
  3. Hood
    Hood Forum Supporter
    9,957
    Carnoustie, Scotland
    I prefer taps in a normal drill chuck, if they grab they will turn and not break.
    For the headstock I bought a collet chuck from J & L recently, it will mainly be used in the CNC but can be put in the manual as well, just grip it in the standard chuck.
    addjunkie and pressbrake1 like this.
  4. Hood
    9,957
    This is the one I bought.
    eLuSiVeMiTe likes this.
  5. pressbrake1
    pressbrake1 Forum Supporter
    1,748
    essex england
    Ive got er40 in morse taper
    Bigger is better as they say and that the size collets I have for the mills
    Hopefuldave likes this.
  6. Hood
    9,957
    All of my collets are ER16 or 32 so that is why I got the 32 for the lathe. Have loads of DA collets as well but all the holders are Cat/BT/Int 40 which fit the Beaver Mill so never use them :D
  7. Milkybars
    Milkybars Member
    172
    Essex
  8. Brad93
    6,594
    Essex
    Have you got a link Hood?
  9. Hood
    9,957
  10. MattH
    MattH Member
    3,651
    Bristol
  11. Hood
    9,957
    I really need to get out of the habit of calling them J & L, they have been MSC Direct for a long time now :D
  12. Kram
    Kram Member
    682
    Sussex
    For spindle you want a backplate mount or you wont get anything down the spindle, I use mt3 for milling. I didnt want to pay 60 quid for a backplate so I got another cheap mt3, cut the taper off, and shrink fit it into a 100mm lump of steel, and recut the taper.
    Tailstock I have a couple of very cheap er11 mt2 with centre and drills always fitted - saves messing with drill chuck when Ill be using a boring bar after. Will be making a floating tap /die holders when I get round to it.
    Brad93 likes this.
  13. Brad93
    6,594
    Essex
    L00 backplate is over £100
  14. Wedg1e
    Wedg1e They call me Mr. Bodge-angles
    6,165
    Teesside, England
    Try and find a used catchplate, I have a 6" 3-jaw chuck mounted on one.
  15. Kram
    Kram Member
    682
    Sussex
    Are they complicated to make?
Advertisements
