modifying a trailer
  1. brokenbiker
    brokenbiker Member
    10,437
    Llanbobyll, south wales
    where would i stand within the eyesof the law/DVSA if i were to modify a trailer by making it a little bit wider (about 6") and turning it from a box trailer with a wooden floor to a ally floored flat bed?
    at the moment its got a 2.7T plate weight...i wouldnt need to alter the track of the wheels, or modify the axles at all as the bed sits above the wheels, just need to remove the wood, cut the frame down the middle, widen it by 6" or so, and then sheet it out with Ally checker plate which would be riveted on...
  2. frank horton
    frank horton V twins are great but 4"s rule.........
    1,412
    Soon 2 B Crete
    make a good job of the join, copy factory finish.......use their rivets etc etc....
    say nowt, who's to know......??????
    just don't do the mod in the street....
    barking mat and Hopefuldave like this.
  3. brokenbiker
    brokenbiker Member
    10,437
    unfortunately my only choice at the moment is to do it on my mothers drive...although no one round here ever takes any notice of what im doing...
    the join will be invisible, once its welded i will be sanding the welds back and painting it anyway...
  4. bourbon Member
    517
    Lichfield UK
    Jobs a good un then. I'm looking at a trailer at the weekend to do 'a little bit of welding'. yeah, right, How many times have we heard that before?
  5. brokenbiker
    brokenbiker Member
    10,437
    to be honest ive looked at about 6 now and am coming to the conclusion that if i can find enough flat space for a few weeks im just going to make one...not sure about getting it tested and getting a weight rating on it though as the race i go to is known for DVSA waiting on the motorway to pull people with trailers coming out of there...had 3 lads last month, all home made trailers and all prohibited until things had been sorted
  6. armalites Member
    4,185
    Herefordshire
    There is no law against using a homemade trailer as long as it was built before the law changed. There should be no issues with your modification, you just need to make sure you aren't overweight, it's not dangerous, the brakes/lights/tyres are all good. Don't forget if they tug you they aren't only going to go check your trailer they going to check everything.
  7. brokenbiker
    brokenbiker Member
    10,437
    yeah ive worked alongside DVSA and been involved with removing unsuitable vehicles from the road...not a question i want to ask them though as even though some of them are friends...i still donttrust them in this respect...
    the tow vehicle is going to suitable, the load will always be strapped down within IVR codes and regs, just wantt o make sure the trailer mods arent going to be an issue and obviously i have the correct licenses and insurance etc...
    the vehicle on the trailer will be registered to me but never used on road etc
  8. colnerov
    colnerov Member
    3,231
    Nr Gatwick UK
    Hi, What about bolting or welding a length of 3" box or channel along each side of the trailer? That way you haven't altered the main structure of the trailer.
    Colin
    Hopefuldave likes this.
  9. nickk Forum Supporter
    1,873
    Hay-on-wye
    He wants to WIDEN it,not lengthen it !
  10. colnerov
    colnerov Member
    3,231
    Nr Gatwick UK
    That's why I said fix it to the sides.
  11. p0689109 Member
    1,696
    stoke on trent,england
    He would be widening it by 6 inches if its added to the sides!
  12. Robotstar5
    Robotstar5 Casanunda Staff Member
    17,862
    Birmingham
    by making it a little bit wider (about 6") which is what he wants
  13. rtbcomp
    rtbcomp Moderator Staff Member
    18,615
    Sheffield UK
    Sounds like a repair rather than a modification :thumbup::whistle:
  14. nickk Forum Supporter
    1,873
    Hay-on-wye
    Get it now !
  15. brightspark
    brightspark Member
    27,377
    yarm
    just do it :laughing:
    stuvy likes this.
  16. Shedendman
    Shedendman Member
    3,688
    east sussex
    Yep,shut ya gob,say sod all,you're doing it for a mate,job done:thumbup:
    brightspark likes this.
  17. Justme
    Justme Member
    2,846
    Pwllheli Wales
    You will need to get it IVA tested as you are substantially altering it.
  18. Justme
    Justme Member
    2,846
    Pwllheli Wales
    This is the reply I got to a similar question I posed to the DVSA:-
    Approvals,
    Customer Service Centre,
    DVSA,
    Ellipse,
    Padley Road,
    Swansea,
    SA1 8AN.
    Good afternoon Richard,
    Thank you for your enquiry regarding this matter which has now been passed to me, as the Technical Officer advising on M1, N1 & O1 Individual Vehicle Approval (IVA) matters.
    If you were to make a new trailer, then yes it would require Individual Vehicle Approval (IVA) prior to it being used on the road.
    If you were to convert a car or trailer to make a new trailer, then yes it would also require an IVA prior to it being used on the road.
    If you were to take an existing trailer and simply mount a new body to it, then no it would not require an IVA prior to it being used on the road.
    This is covered in paragraph 5 (Scope of the Regulations) of Part 1 of the Road Vehicles (Approval) Regulations 2009.
    I have attached further information regarding the IVA scheme, which I hope will be useful and can be found by following the links below:
    VEHICLE TYPE APPROVAL - https://www.gov.uk/vehicle-approval/when-you-need-vehicle-approval
    IVA - https://www.gov.uk/vehicle-approval/individual-vehicle-approval
    (Includes links to the Model Report list on the VOSA site, list of Technical Services, the IVA Guide, Test Stations and POTFs)
    IVA MANUALS - https://www.gov.uk/vehicle-approval/individual-vehicle-approval-manuals
    IVA FORMS - https://www.gov.uk/apply-vehicle-approval
    skotl likes this.
  19. skotl
    skotl Forum Supporter
    6,565
    Edinburgh, UK
    So... thinking of Trigger's Broom, I replaced the axle, wheels, hitch, jockey wheel, wood and light board on my trailer, leaving the chassis intact. Oh, and rebuilt the suspension (but retained the original springs).
    Is that the same trailer?
    Pigeon_Droppings2 and Shedendman like this.
  20. stuvy
    stuvy Member
    Manufacturers like for like?
    Justme likes this.
Advertisements
