Miniarcmig 200
  1. how easy a job is it to replace torch liner
  2. arther dailey Member
    3,281
    Southampton England
    if its the same as 180 pretty straight forward
  3. wyn
    wyn Member
    2,999
    Cardiff
    It's pretty easy..this pic is my 180.
    Remove the wire reel.
    Remove the top roller with an allen key.
    Remove the plastic cone the wire runs through..torx screwdriver (red arrow).
    Undo the nut holding the liner (blue arrow)...10mm while holding the bigger nut..17mm.
    Remove the liner.
    There will be an o-ring on the liner that needs to go back on if the new liner doesn't have one.
    Remove the tip and gas diffuser and fit liner...trim to length and refit bits.
    Put all the bits back on.
  4. Hitch
    Hitch Moderator Staff Member
    11,988
    Somerset
    You can get a euro adaptor kit for the miniarc, I upgraded the 180 at work to that, as the gas pipe kept fracturing where it comes out of the machine.
    Not sure if the 200 is the same
  5. Country Joe Argoshield Dark
    1,249
    Somerset - United Kingdom
    Ahoy there, Hitch!
    Yes, the 200 is the same - mine's got a euro adaptor on it.
    All the Best,
    CJ
Advertisements
