Mini rotary tool grinding stones
  1. RonA
    RonA specialist in repairing sealed for life equipment
    1,501
    Stockton on Tees, UK
    Bought a rotary tool (dremel like) some time ago & it came with rotary grind stones (cones, tapered, round).
    I have used these & found them very useful for numerous tasks but the stones don’t seem to last, they tend to fall apart before they wear out.
    Anybody recommend a source of quality grinding stones, the tool itself seems up to the tasks I’ve set it.
    RonA
  2. brightspark
    brightspark Member
    28,939
    yarm
    RonA and gordon stephenson like this.
  3. Ton-up
    Ton-up Member
    1,505
    Essex, England.
    Lidl have 'Dremel' type tools for sale next week. I have been pleased with them in the past and will be going to get more.
    https://www.lidl.co.uk/en/c/diy/c1322/w2
    If you click on the tray of cutters, not the tub of assorted accessories, they have exactly what you want, 2 for £4!!
    gaz1 likes this.
  4. Kram
    Kram Member
    1,080
    Sussex
    Never liked the stones. Get fine toothed 3mm carbide burrs for metal, they last forever also being quicker. Even better 6mm shank burrs in a die grinder. For soft materials plastic and rubber, a tyre golf ball, but I have only seen with 6mm shank.
    Could use a new burrs if anyone can recommend, my 3mm is snapped but still useable and the 6mm both over 10 years old. They get a lot of use -every time I drill a wonky hole and it needs be adjusted.
    RonA likes this.
  5. Brad93
    Brad93 M J B Engineering
    7,434
    Essex
    They’re called mounted points.
    Buy the best you can afford.
    Pferd are great. Otherwise Norton, SAIT, Kingspor etc.
    RonA and eLuSiVeMiTe like this.
  6. Brad93
    7,434
    Essex
    pferd
  7. Shox Dr
    Shox Dr Chief Engineer to Carlos Fandango
    14,802
    East Yorkshire
    I thought they were mini grenades, as they explode on me after 5secs:laughing::mad:. Always used burrs when Pushed to use one. Never found them to be good at anything.
    Once walked past a guy cleaning his drive gates with a wire wheel:laughing: god knows how long it took him, if they ever got finished. I didn't bother him, he looked busy
    RonA and zx9 like this.
  8. earthman Member
    1,266
  9. pedrobedro
    pedrobedro Man at Matalan
    10,247
    CX Derbyshire
    My main tool for grinding with my Aldi version is the rubber expanding drum with the abrasive sleeve. I buy replacements whenever I see them on sale.
    Hopefuldave likes this.
  10. Brad93
    7,434
    Essex
    A set of decent carbide burrs for Steel from Pferd will set you back about £100. Most of the 6mm shank burrs are £20-30 a piece.
    I’ve some micro cut burrs that are great too.
    Mounted points are much better for deburring or chamfering.
  11. RonA
    1,501
    That’s exactly my experience of the grinding stones (points) that’s why I’m looking for something better.
    RonA
Advertisements
