take it from me dont its very bright and also gives the illusion your burning through when infact you might not have been doing and then sometimes its more than likly you have got a hole in the metal your welding
if you want to learn mig welding do it by gas you will learn more than you think that way
if not and you dont want to listen then go for arc as you might as well it would be cheaper but you can only weld 2mm and above gasless is roughly the same unless you have had experience
ive got a bit of experience with arc before i tried mig i can only just weld 1mm with years behind me and even then i can and do burn through
