I Ian.stewart New Member Messages 6 Location UK Nov 25, 2022 #1 I have to modify a previously used stainless exhaust manifold, can I use argomix to weld the stainless, using SS wire,
Hitch Moderator Staff member Messages 13,536 Location England Nov 26, 2022 #3 Yes and no.... Depends on the mix, im guessing your talking argoshield light or equivalent? Yes it will stick it together... Is it the correct choice...technically, no its not.
backpurge Member Messages 2,397 Nov 26, 2022 #4 For what you are doing it should be ok, as said above, not ideal but it will do
H hotponyshoes Member Messages 7,486 Location Somerset. Uk Nov 26, 2022 #5 I'd guess you'll get more problems from the exhaust being previously used than you will from the gas mix!
T tom2207 Member Messages 7,212 Location uk northern ireland Nov 26, 2022 #6 I do it often , and normally its grand ,, bit off color , and fugly , but it works.
