Mask that actually fits?
  1. julianf
    julianf Member
    4,864
    devon, uk
    I've never found a mask that fits. Not the disposable ones, nor the (very limited) number of units with separate filters.
    Can anyone recommend anything?
    I'm only really after somthing for particulates. Just general dust etc. I have an air fed for proper toxic stuff.
    I realise face shape will mask a difference - pointy, boney, with some hair.
    Ie the opposite to fat, round, and smooth!
  2. Climber
    Climber Member
    500
    Hampshire UK
    eLuSiVeMiTe likes this.
  3. zzr1200
    zzr1200 Working at 650 ft on open steel work
    3,920
    Glapwell, Chesterfield, Derbyshire.
    See if you have an "Arco" somewhere near you, they should allow you try the masks on they have in stock, hope you find a comfortable one.
  4. akdaka Member
    49
    Wiltshire
    +1 for the 3m mask
  5. Dcal
    Dcal Forum Supporter
    2,219
    Antrim Northern Ireland
    I've never found a disposable "paper"mask that fits or is worth wearing (even the expensive ones.)
    For disposable I like the 3m 4000 series and for replaceable filter type the 3m 6000
    I find the 4000 nicer to wear but the only facial features I share with you is the hairy bit.
    You need to try for yourself but 3m do offer 3 face sizes in their masks.
    A face fit test would be well worth doing.
    ARCO offer the service.
    Anguz likes this.
  6. Turbo Member
    3,656
    Fermanagh, Northern Ireland
    I'm blessed with a large nose & the only mask that's comfortable for me to wear plus seals properly is a 3m 7000 series. They come in 3 sizes, small, medium & large, mine is a 7502 medium. It's made from nice soft silicone rubber & I can wear it all day with no problems.
  7. hotponyshoes Member
    2,921
    Somerset. Uk
    If you don't mind a full face the scott vision series come in 4 sizes with a choice of filters
  8. Maker
    Maker nEw mEmBeR
    7,648
    Don't ask questions
    I believe mine is the same, fits me well enough but I don't have Julian's face so that doesn't really mean anything. :whistle:
  9. Anguz
    Anguz Forum Supporter
    636
    bedfordshire
    Face fit test is the way to go
    Tangledfeet and winchman like this.
  10. gaz1
    gaz1 Member
    10,928
    westyorkshire
  11. Parm
    Parm Oh how I’ve missed my play pen this year
    12,352
    Towcester
    As said get yourself along to an Arco, they have the largest range of selection of respirators that can be tried on.
    Take some sterile wipes with you !
    One thing worth noting is that if you have even the smallest amount of facial hair or stubble the level of protection is drastically reduced even with a correctly fitting mask.
    If you’ve got the air fed, stick with that and save yourself some money on masks and or filters
    winchman, Turbo and slim_boy_fat like this.
  12. morssdn
    morssdn Member
    256
    Stirling, UK
    3M 7502 Series comfy and effective, fits under Speedglas welding lid.
    [​IMG]
    you get pairs of twist fit filters that go on the side. recommended. I find disposables a bit useless.
    davidjohnperry, 8ob and gaz1 like this.
  13. Jim Davey
    Jim Davey R H Davey Welding Supplies Ltd
    5,466
    Southampton
    I use this one quite a bit, very good fit (for me) and comfortable, if a little sweaty during the summer.
  14. MattF
    MattF Member
    10,439
    South Yorkshire, England
    If it's just for nose & mouth, (if they still make them), those little alloy clip frames where you used to fit something resembling a sterile patch to them were ideal for weird shape faces. You moulded the frame to fit your mush.
  15. WorkshopChris
    WorkshopChris Forum Supporter
    4,968
    South East Essex
  16. Parm
    12,352
    Towcester
    That’s called a Martindale Mask
    Save your pennies and just use a tissue, it will be more effective
    WorkshopChris likes this.
  17. Hitch
    Hitch Moderator Staff Member
    12,314
    Somerset
    Bandana tied round your face, like Le Salvager :laughing:
    Personally I get on well with a Scott Profile2 Halfmask. Very flexible around the face fitting. And no steaming issues with glasses.
    For disposable, the 3m Aura 9322 are okay, but need a little squeeze now and then to readjust.
    Parm and Maker like this.
  18. chris pruteanu Member
    895
    ROMANIA
    If you can live with an air feed mask then look no further than the speedglas 9100FX with the adflo extractor on it- really worth its weight in gold ! A bit cumbersome to wear as its a bit heavier than a simple mask but so versatile ! The grinding face shield is really good and peripherial viewing angle is huge ! Yes, they are pricey but a really nice bit of kit altogether !
  19. MattF
    MattF Member
    10,439
    I always liked those masks, personally.
  20. Turbo Member
    3,656
    Having used a Trend Airshield Pro at the Men's Shed I would buy one of those if I could afford it. It will only protect from dust but it's oh so nice having cool air blowing round you face on a hot day.
Advertisements
