ab56452001
Big Al
- Adelaide South Australia
Hi all , I have had this Lotos with pilot start for a few years , hasn't really seen much work . The other day I was cutting some large sheets of 3.5mm steel plate , after a while the cutter started playing up , sputtering , stop starting and so on . I changed out the tip ( which was blocked ) and shroud, checked air and ground and tried to continue , no go !. The unit fires up , half heartedly runs for a second or to then nothing , after a few tries even the pilot no longer works , by the way no overheat light ever came on . The air solenoid works as I can hear it , is this machine toast or ( hopefully ) it is only a simple problem , cheers from OZ .
