Lightweight galvanised steel
  1. desmo11225 Member
    190
    Luton Bedfordshire UK
    Hi Everyone
    I am looking for very lightweight galvanised steel ,the type used for shelving but flat , it is to screw onto the back of half inch mdf to stop it bending in the middle along its length 8 feet ,needs to be light but very rigid . Would someone be able to help me please. thank you in advance. desmo11225
  2. piman Member
    1,734
    Oswestry Shropshire
    Hello Desmo,
    I think you are asking a lot. 8 ft of 1/2" mdf is very flexible. Screwing metal to tehe back is difficult as the MDf deoesn't take screws very well in that plane, (Just like screwing into end grain of wood, it's not very strong). I would suggest the best way is angle so that can be screwed into the lower face, even then it will probably need to be something like 3mm thick aluminium or so to keep it rigid and light.
    Alec
  3. zzr1200
    zzr1200 Working at 650 ft on open steel work
    3,872
    Glapwell, Chesterfield, Derbyshire.
    Considering what you want to do and support, you would probably be better off using 19mm ply and I doubt there'll be much difference in cost...
    WorkshopChris likes this.
  4. WorkshopChris
    WorkshopChris Forum Supporter
    4,927
    South East Essex
    rtcosic likes this.
  5. Morrisman
    Morrisman Forum Supporter
    2,321
    Staffordshire, England
    My sister used 3/4” MDF for some shelves, 12” wide, 8’ long, with three angle brackets, in her garage. Over the last six months they have sagged nigh on two inches between brackets, even with minimal weight on. Plywood wouldn’t have done that.
  6. mtt.tr
    mtt.tr Member
    3,144
    Essex England
    tradionally you lip shelves, glue and screw a 50+ mm deep mdf lip on
    like this
    [​IMG]
    Olderisbetter likes this.
  7. Olderisbetter
    Olderisbetter Forum Supporter
    2,787
    Wolverhampton
    Been there done that got the Tshirt that fell off the shelf, MDF is fantastic for cost effective building but when it comes to long spans you need support point or to get something with a grain or laminated layers, I did some 6 foot MDF shelves recently and had to add 3mm wall 18mm square ally box section front and rear, Next week i am doing some 2400mm x 235 mm x 18mm clear pine as i dont have the time to mess about with engineering a way round the sag and flexing, Not cheap but saves a lot of running round and failing later on.
    Ali likes this.
  8. Morrisman
    2,321
    I’ll point that out to my sister. it :D
  9. outofthefire
    outofthefire Member
    2,303
    Leeds
    bigegg and Seadog like this.
  10. Morrisman
    2,321
    Well “the type used for shelving but flat” is hardly a brilliant feckin description of what is required!
    Glad to see you know exactly what he wants though.....
    mtt.tr likes this.
  11. bigegg
    bigegg I drink and I know things. Its what I do.
    7,507
    Leeds, West Yorkshire
    fh brundle do sheets from 0.8mm.- its as bendy as mdf though.
    you'll need to add pleats, or go to 3mm+.
    or use 6mm aluminium.?
    if you use steel, i suggest gluing it to the mdf: theres an impact glue i've used called thx38(?) to glue steel to plywood to make a caravan door. *incredibly* strong.
    <edit: tx528 impact adhesive.
    thx38 is a droid from star wars. :D>
  12. outofthefire
    outofthefire Member
    2,303
    Leeds
    Calm down Gloria "I am looking for very lightweight galvanised steel" was the initial question.
  13. slim_boy_fat
    slim_boy_fat Forum Supporter
    Here we go again..... :whistle:
    Seadog, Yamhon, bigegg and 2 others like this.
  14. desmo11225 Member
    190
    Thank you everyone for all your comments, I'm sorry that my discription was a bit vague , I can see what we need but it is hard to discribe it , I'm sure we'll get there in the end . Thank's again . desmo 11225
  15. RWD3M
    RWD3M Member
    949
    Wiltshire, UK
    I have some galvanised steel sheet at 20 swg so it's out there some where. Unfortunately I put mine through the guillotine to get them in the car (they were originally 8' x 4') :doh:
  16. bigegg
    7,507
    companies which make ductwork get it in 3mx1.5m sheets (or 8x4).
    fh brundle stock it in various thicknesses.
    RWD3M likes this.
Advertisements
