123hotchef
- Kent
After removing the outside lamp due to the lamps keeping blowing it appears I have a earth to neutral fault because I have a erratic resistance reading across the 2. I am just going to whip the other out side lamp off and check for water ingress there as it could be the problem I guess although that light works perfectly fine.
Any other suggestions.
The 2 out side lights are on the down stairs ring the other lights are are LED down lighters and work fine
