Just painted a few different parts (oil tank, petrol tank and mudguard) last night in the well recommended Lechler Epoxy primer. I'll be leaving this until tomorrow to fully cure. What prep is recommended before applying any filler or can it go straight onto the painted surface? I would normally expect to key the entire surface with 240 then apply the filler to the areas required.
Also the other question is if going over the top of the epoxy with a 2k surfacer primer (octoral is my personal choice), does the epoxy need keying prior to surfacer primer or can it be applied straight on top of a cured epoxy surface.
Thanks in advance.
Thanks in advance.
