yea it needs 25 to work do you take the lead from the fuse box are do you get a 13 amp plug plug it in then have a special plug
Yes you can. That model has 12 voltage settings. It needs a 25amp supply just on the top 2 settings; a standard 13amp supply will be fine up to around 150-160amps (4-5mm mild steel). What type of work do you want the machine for?also the welder is swp mig 220 i was wondering could you put a full size welding bottle on it.
i heard about a welder which kept cutting out the man changed the breaker in fuse board to a industrial one and it worked then could i not just do that
Not sure of the amp rating of a M6 BOLT!!
You need a 32amp plug (closest size up from 25amp) on the supply cable of your welder.
From the electrical supply be it a consumer unit or distribution board you need a 32amp socket protected by a C or D type 32amp MCB depending on the welder.
The cable size from the distribution board needs to be a minimum 4mm squared diameter depending on how long the run is and depending if the cable is run in free air, clipped direct or run in thermal insulation. The most likely size of cable you will need will be 6mm squared to be able to safely carry the current required at full load but the IEE wiring regs will need to be checked to be sure.
Such a supply can be run from your house so long as it is a single phase welding set and not 3 phase and providing it is wired to current wiring regs.
If any of the above sounds like a foreign language you should definitely consult a qualified spark, IE. me.
so i need a bigger fuse to put in the plug, like the bolt as a fuse i wouldnt do something like that i hope
