Harrison m500 gearbox parts wanted.
  1. andy176 Member
    24
    Ni
    Hi I have a Harrison m500 which has just took 4 teeth of a gear at the bottom of the spindle gearbox which drives onto the gear ring on the spindle it's a 52 tooth gear. Does anyone know of any for breaking or anyone who would have the parts, I can buy new but have to buy all 3 gears and the shaft I think the 400, 450 and 550 may be the same any help is appreciated thank.
  2. Pete.
    Pete. Member
    8,559
    Kent, UK
    Andy,
    Do you mean the screwcutting gearbox or in the headstock? If it's in the headstock it's quite likely to be non-standard.
  3. andy176 Member
    24
    Ni
    Hi Pete
    Yea it's the headstock where the spindle is driven from. Yea it will Harrison/600 group part was hoping to find one breaking as I'm not 100% sure what has caused it to break teeth and hesitant to spend the money on a complete gear cluster for it to do it again as I was only screw cutting at the time it happened.
  4. Spark plug
    Spark plug Member
    3,391
    Durham, England
    The gear that is damaged, is it fixed or does it slide on its shaft? Is it possible it was meshed with two gears at once, caused by a weak detent possibly?
  5. Brad93
    Brad93 M J B Engineering
    6,251
    Essex
    You need to figure out what went wrong before buying new ones.
    There’s a company in Basildon, they make gears from scratch, I can get you their details if you want from my Machinist friends at work.
    eLuSiVeMiTe likes this.
  6. Brad93
    6,251
    Essex
    @pressbrake might be able to advise he is very knowledgable when it comes to big lathes.
  7. Ton-up
    Ton-up Member
    1,383
    Essex, England.
    M.G & A. Engineering.
  8. Brad93
    6,251
    Essex
    That is most likely the one
Advertisements
