planning on moving my 216am welder but the current cable isn't long enough.
Long as it doesn’t let the magic smoke out, all’s good.If you are extending the current cable, be sure to extend the voltage one at the same time or the pixies will spill out on the floor before reaching the welder.
eh?If you are extending the current cable, be sure to extend the voltage one at the same time or the pixies will spill out on the floor before reaching the welder.
Just get yourself a 2.5 mm h07rnf extension cable, buy 25m then you can use it for anything, plugs of your choice.I used 2.5mm² h07rn-f, but 1.5mm would be adequate depending how long.
it'll be permanently fixed. just going to rearrange working space to make a little more room in my bike part of the shed..Just get yourself a 2.5 mm h07rnf extension cable, buy 25m then you can use it for anything, plugs of your choice.
Doesn't the Ohms cable prevent that?If you are extending the current cable, be sure to extend the voltage one at the same time or the pixies will spill out on the floor before reaching the welder.
