Gear lever boot trim
  1. jgr2015 New Member
    3
    Ireland
    A small bit of metalworking in the name of tidying a Mercedes 190.
    The original plastic gear lever boot clips neatly onto a plastic trim piece. However that boot is torn and I couldn't see a way to fit any other boot onto that trim piece so off we go..
    Some brake pipe bent to shape and six clip type arrangements bent from mild steel. All silver soldered together to form this:
    [​IMG]Trial fit into surround:
    [​IMG]
    Then take leather boot bought from ebay, remove not-very-effective elastic from lower edge, fold under pipe, tuck into the clips and crimp clips with pliers to secure. Some contact adhesive on folded edges of the leather to be sure, to be sure:
    [​IMG]
    [​IMG]
  2. Wallace
    Wallace Member
    6,102
    Staines, Middlesex, England.
    Nice job, better than some professional trimmers I have seen.
    stuvy likes this.
  3. Lazurus
    Lazurus Member
    408
    Norfolk uk
    I never have any luck with silver solder, am I missing a trick?
  4. slim_boy_fat
    slim_boy_fat Forum Supporter
    Welcome aboard, @jgr2015 :waving: - that's a well-executed introduction you've given us. :thumbup:
  5. jgr2015 New Member
    3
    Ireland
    Thanks for the kind words. I've learned so much from this site and the forum in particular over a good few years. It's great to finally post something!
    As to silver soldering, I've only done it a couple of times, but what I've done is get the metal nice and clean, apply flux and heat up with a propane torch. I use a Kaolin wool blanket to contain the heat. The flux bubbles a bit and then goes clear. Then feed the solder into the joint from the opposite end to where the torch is concentrated and let the solder flow toward the heat. The only time it hasn't gone right, I put it down to not enough flux - the solder was balling up on the surface and not wetting the base metal. Cleaning the joint, re-fluxing and reheat and it worked a treat.
    The solder I have is high enough silver content from memory which puts it toward the lower end of the melting point scale (630 to 660 deg C). It's also more expensive but a small amount goes a long way.
    slim_boy_fat likes this.
  6. RonA
    RonA specialist in repairing sealed for life equipment
    1,269
    Stockton on Tees, UK
    Bet it worked out a site cheaper than the manafacturers part. Nice job
    RonA
  7. The_Yellow_Ardvark If in doubt ask.
    9,728
    UK
    Clean joints, decent flux and do not under heat or over heat the joint.
    RonA, slim_boy_fat and Lazurus like this.
  8. Tom O Member
    149
    Canada
    What is the best flux for silver soldering just borax or mixed with something to form a paste.
Advertisements
