Gate post repair.
  1. Shaun Henry
    Shaun Henry Member
    33
    Fife
    Afternoon all,
    I had to repair my drive gates the other day. But now I need to move the bottom hinge pin.
    I will be welding outside so my questions are:
    1. use flux core wire or use the gas.
    2. Is it pointless using gas outside.
    Thanks
    Shaun
  2. Dcal
    Dcal Forum Supporter
    2,015
    Antrim Northern Ireland
    If you can keep the wind off it either by doing it on a calm day or using a tarp or similar it should be fine.
    You might also need to up the gas flow a bit.
    8ob, hunter27, anjum and 2 others like this.
  3. Shaun Henry
    Shaun Henry Member
    33
    Fife
    No problem. Perfect thanks. Was starting to think it maybe pointless.
    Thanks again
    Shaun
  4. Shaun Henry
    Shaun Henry Member
    33
    Fife
    So I repaired the gate, used the gas and practiced on prepared and unprepared surfaces (just to see the difference) it is like night and day the difference from flux to gas. Gates on. Been on 3 days and not it the floor yet.
    Thanks for your help.
    Shaun
    jimbo84, Dcal and slim_boy_fat like this.
  5. Dcal
    2,015
    Good to hear you got it sorted and thanks for updating.
    Shaun Henry likes this.
  6. Shaun Henry
    Shaun Henry Member
    33
    Fife
    No problem thanks for your help. Much appreciated
  7. angellonewolf
    angellonewolf Member
    5,238
    bristol england
    was the steel very thick ?
  8. Shaun Henry
    Shaun Henry Member
    33
    Fife
    3mm but the bit with the pin was about 6mm.
    Honestly, I am just waiting on it falling off.
  9. angellonewolf
    5,238
    bristol england
    what amps is the welder that would need a fair bit of power for 6mm ? im no welder by the way but at that size i would have gone with the stick welder
  10. Shaun Henry
    Shaun Henry Member
    33
    Fife
    No idea that's why I am waiting on it falling off. It sturdy tho. This is all new to me.
  11. angellonewolf
    5,238
    bristol england
    got pics of your welder ?
  12. Shaun Henry
    Shaun Henry Member
    33
    Fife
    It's a clarke 151en. No photos
Advertisements
