Fuel tanks & welding
  1. P@ul New Member
    15
    UK, Sussex
    Just starting to prep my landrover for welding which also means removing the diesel tank which got me thinking :confused:
    When you guys are welding on a vehicle when do you decide to remove the fuel tank, how close is to close and do you treat petrol and diesel differently?
  2. mr haynes Member
    226
    uk
    Depends on the job. If it's a patch try to leave in place, a resto would remove tank as matter of course whether welding or not
  3. julianf
    julianf Member
    3,911
    devon, uk
    You can throw a match in a can of diesel and it will just go out.
    Unless you're actually heating the skin of a diesel tank I would have no concern, beyond my usual precaution of having a fire extinguisher to hand.
    brightspark and slim_boy_fat like this.
  4. Tinbasherdan
    Tinbasherdan Bodger in chief
    4,425
    Bolton, England
    I’ve welded diesel tanks with fuel in, it’ll boil long before it flashes. If I’m feeling a bit nervous I chuck a purging line in for 10 mins
  5. doubleboost
    doubleboost Member
    2,547
    North Easr England
    Closer than you would believe
    eLuSiVeMiTe, addjunkie, Parm and 3 others like this.
  6. RonA
    RonA specialist in repairing sealed for life equipment
    1,296
    Stockton on Tees, UK
    I used to test diesel tanks on Sentinel locos prior to welding. We drained the tanks below the leak & then innerted the space above with bottled Nitrogen, checked the Oxygen level in the tank was zero & started welding.
    It’s the old fire triangle fuel, heat, Oxygen, remove one of the legs & your can’t start a fire or explosion (which is only rapid combustion)
    RonA
    eLuSiVeMiTe, Nick67GT, Parm and 5 others like this.
  7. F.J.
    F.J. Member
    1,568
    Manchester
    I’ve TIG welded shelves inside a diesel tanker while still holding a good 4-5 inches of red in it, no problems there.
    I have also tig welded the seam on a 50 year old Massey Ferguson tractor that ran on paraffin and although it was drier than a desert in there you should of heard the bang it made. Once I’d come to my senses I couldn’t stop laughing as all the swage lines and shapes had blown out of it and it was shaped like a ball!
    eLuSiVeMiTe and johnik like this.
  8. pedrobedro
    pedrobedro Man at Matalan
    9,608
    CX Derbyshire
    Only tank I ever removed was on a mk4 Cortina and that was because I needed to get above it. Diesel I would not worry about.
  9. p0689109 Member
    1,623
    stoke on trent,england
    As it is a LR I would remove it to check for more corrosion!
    Westfield-builder and Parm like this.
  10. P@ul New Member
    15
    UK, Sussex
    Thanks for all the replies, looks like I've been over cautious.:D
  11. The_Yellow_Ardvark
    The_Yellow_Ardvark If in doubt ask. Same rules for everyone
    10,367
    UK
    Better safe than sorry.
Advertisements
