Front suspension strut removal socket
  1. jgr2015 Member
    25
    Ireland
    Hi All,
    I needed to replace the top mount on a Mitsubishi Lancer and hey presto the top of the strut has a section with two flats which needs to be held stationary while the nut below is rotated.
    [​IMG]
    So, below a solution .... a homebrew version of the manufacturer special tools...
    [​IMG]
    I milled two flats on the 17mm 1/2 inch drive deep socket to take a conveniently sized 25/32 inch wrench... The socket was horribly tough to mill even with an inserted carbide cutter (especially as I'm new to milling work). The narrowest portion of the socket was bored out on the lathe to pass a 3/8 inch socket extension.
    Then starting with a piece of 16mm round steel (EN24T as far as I know), I milled out a 3/8 inch square recess on one end and the necessary flat sided recess to fit the strut on the other end.
    [​IMG]
    [​IMG]
    And this is how it fits in use...
    [​IMG]
    For reference and for anyone searching, , the Mitsubishi special tool is part number MB991680 comprised of MB991681 and MB991682.
    The top mount is now changed incidentally. And there was much rejoicing.
  2. pedrobedro
    pedrobedro Man at Matalan
    10,508
    CX Derbyshire
    I use a cranked ring spanner and an open ender or a deep socket and the rattle gun.
    Rig Pig, Wallace, premmington and 3 others like this.
  3. MoreWellie Forum Supporter
    1,227
    Bedfordshire, UK
    I usually use an 8mm spanner
    funny how many 8mm spanners I have got through over the years...
    Hopefuldave, stuvy and SteScouse like this.
  4. atomant48
    atomant48 Forum Supporter
    926
    Salisbury, UK
    Nice solution. I had the same issue on a polo a few years ago and chopped a socket in half and welded it to a bar with a hole through it.
    Then when faced with the same issue but different size socket on the next car I splashed out on a Vortex (pass through) socket set and have used it only a couple of time but it’s worth it’s cost. One of the few tools I would loan if anyone ever needed it for that exact job.
  5. grim_d
    grim_d Unlikeable idiot.
    2,949
    Scotland - Ayrshire
    Get yourself a decent set of swannies old boy!
  6. Ruffian Member
    2,491
    Devon UK
    Welded sockets to angle grinder keys before for other types with the Allen key centre.
    Usually now a decent nut gun will blip the nut off easy enough without holding the strut.
    stuvy likes this.
  7. Migmac
    Migmac Forum Supporter
    4,433
    Kintyre. Scotland
    My son and I have just done two. Can’t for the life of me remember how we did them, he must of brought the right tool for the job from work. I don’t recall any swearing or falling out
    stuvy likes this.
  8. doubleboost
    doubleboost Member
    3,027
    Newcastle upon Tyne England
    Mole grips on the very top of the damper rod then a windy gun
  9. stuvy
    stuvy Member
    Rubber oil filter wrench for defenders and a gun on top;)
    Dcal likes this.
  10. frank horton
    frank horton V twins are great but 4"s rule.........
    2,068
    Soon 2 B Crete
    never had the need...
    a good 1/2" air gun and 150psi does it for me.....everytime.....
    8ob likes this.
  11. Turbo Member
    3,668
    Fermanagh, Northern Ireland
    After years struggling to undo them the correct way using hand tools I came across a strut so tight it wouldn't budge. Discovered the grips & windy gun method, now I use nothing else! ;)
    stuvy likes this.
  12. p0689109 Member
    1,775
    stoke on trent,england
    How does the windy gun socket combination get on if the mole grips are on the two flats at the top in the way?
  13. Ashley Burton
    Ashley Burton Member
    4,486
    Northamptonhire
    I think they are holding the shock shaft instead with molegrips
  14. aguycalledsteve
    aguycalledsteve Member
    540
    Mansfield
    As above, cranked ring spanner and an open ender/adjustable to hold it. Buzz gun off once it's free..
  15. Cobbler
    Cobbler Codger bodger
    5,261
    Gloucestershire UK
    I did some struts years ago & nothing would hold on the chrome shaft enough to allow it to undo. Strut was scrap anyway, so out with the arc welder, large splodge of weld through the spring with welder turned up to burn through the chrome. This allowed a pair of stilsons to grip the shaft, worked a treat.
  16. bricol Member
    1,265
    N.Yorks, UK
    Don't usually need the grips - usually enough resistance to the shaft rotating for the gun to spin the nut off.
    If there isn't, shove the bump stop down and grip the very top of the shaft under the top mount - the bit that won't be sliding past seals due to the bump stop, so it doesn't matter if you damage it slightly.
    doubleboost likes this.
  17. 8ob
    8ob Forum Supporter
    6,112
    moscow on thames
    Windy gun normally does it for me.Thats not to detract from the cracking job @jgr2015 has made of that proper tool, at least he gets to torque up the nut instead of just guesstimating the gaddagars
    Bob
    Ashley Burton likes this.
  18. Ashley Burton
    4,486
    Northamptonhire
    @8ob can't beat some ugger diggers!
    Until the socket carrys on spinning... :laughing:
    8ob likes this.
  19. doubleboost
    doubleboost Member
    3,027
    That osthe
    That is the way it done in the trade Normally gust needs the gun
  20. jgr2015 Member
    25
    Ireland
    It's good to hear the collective wisdom of this site as always.
    I reckon I've just about time to get an email to Santa for a decent windy gun.
    And on that note Happy Christmas to one and all !
Advertisements
