Fork oil
  1. winchman
    winchman Member
    2,305
    Merseyside
    Now back to the Honda XL.
    Had a big fight with the forks, they are in bits now when I rebuild them should I use fork oil or is there a cheaper alternative? Could put the old smelly stuff back?
    Only stripped them to powder coat the leg things
  2. eLuSiVeMiTe
    eLuSiVeMiTe Grumpy Youngish man.
    4,848
    Bedfordshire England
    Stick with fork oil mate. Worth buying a brand you can blend. Good for tuning forks to desired feel mixing weights
    8ob and zx9 like this.
  3. mike os
    mike os just a little insane.....
    5,513
    North Wales
    Stick with a good brand of fork oil
  4. Rannsachair
    Rannsachair Forum Supporter
    713
    Lochgilphead, Argyll, Scotland
    It is not too expensive for all the oil forks take I usually go go for Castrol, Fuchs, Motul or Halfords own.
  5. frank horton
    frank horton V twins are great but 4"s rule.........
    902
    manchester, UK
    if ur stuck or out of brass Red Auto transmission oil will do.......all my Harley's got that......no probs......
    slim_boy_fat likes this.
  6. pedrobedro
    pedrobedro Man at Matalan
    9,099
    CX Derbyshire
    Get some good oil and don't put too much in or the seals will leak. And don't reuse the old seals and stop being cheap it doesn't always pay in the long run
  7. winchman
    winchman Member
    2,305
    Merseyside
    But I well known for my short arms and deep pockets
    pedrobedro likes this.
  8. dobbslc
    dobbslc Forum Supporter
    3,487
    Hertfordshire UK
    I've used Rock oil and it seems good stuff.
    The old smelly stuff you drained out probably was old fork oil......
  9. winchman
    winchman Member
    2,305
    Merseyside
    Just ordered new seals, will order some oil next week very difficult to remove, don't look damaged but might as well fit new as I don't want to re assemble and find they leak!
    I was really struggling and didn't want to damage them so went for a cup of tea and looked on line! No I didn't do it this way.
    I used this, just luckily I had a couple of larger ones worked a treat
    https://www.zoro.co.uk/shop/automot...qhRlfIVWUAmPkr6xNTX9v-8-F1AfsTyRoCSnYQAvD_BwE
  10. pedrobedro
    9,099
    CX Derbyshire
    Last ones I did the seals cost £7 a side. The ones that came out didn't look damaged to the naked eye but the oil was coating the disc on one side. Check the stanchions for nicks and rust spots while they are out.
  11. slim_boy_fat
    slim_boy_fat Forum Supporter
    My Dad used to say "Buy cheap, buy dear" :vsad: - but that was before the days of Banggood, I wonder what he'd have made of them and their likes.....:D
  12. eLuSiVeMiTe
    4,848
    Alway known it as buy cheap buy twice.
  13. slim_boy_fat
    Same idea, but being Scots the emphasis was on avoiding shelling out twice to get the same job achieved. :laughing:
  14. mangocrazy
    mangocrazy Italian V-twin nutjob
    527
    Sheffield, UK
    Swimming against the tide here, but Honda used to recommend ATF (10 weight) for the older damper-rod type forks. Not sure what is fitted to the XL, but they do stand a chance of being damper rod forks. If the forks are cartridge type, use the correct grade of proper fork oil. I like Silkolene or Motul.
  15. Shox Dr
    Shox Dr Chief Engineer to Carlos Fandango
    12,779
    East Yorkshire
    Use shock oil. We used Putoline. But others are as good.
  16. Tinbasherdan
    Tinbasherdan Metal mangler
    3,885
    Bolton, England
    Use cheap or old fork oil and they’ll be in short casts too. Crap oil can make a great handling bike feel like an absolutel horror to ride and be downright dangerous
    addjunkie and eLuSiVeMiTe like this.
  17. Ashley Burton
    Ashley Burton Forum Supporter
    1,932
    Northamptonhire
    Fork oil isn't even expensive when I bought some Putoline stuff
  18. PhillipM
    PhillipM Member
    1,615
    Rotherham
    Rock Oil is okay and stocked most little shops, cheap too. I run Silkolene RSF in more vital stuff, which is the dogs danglies and probably not much more money given how little you need for a bike (It is when your dampers take about 12 litres though :D )
    eLuSiVeMiTe likes this.
  19. eLuSiVeMiTe
    4,848
    Belray was specced for my last bikes Showa forks. Expensive but worthwhile. In trials suspension setup is critical
    Check a manual for your year for Hondas recommendation
  20. Bill Edwards Member
    4,658
    Scarborough, North Yorkshire
    To a non biker, what’s special about fork oil?
    What exactly does it have to do that something such as ATF, thin engine or hydraulic oil can’t?
Advertisements
