Forced patina techniques.
  1. julianf
    julianf Member
    4,428
    devon, uk
    I've got a project on that I need to set apart from others.
    I've got there steel boxes -
    IMG_20190705_231649775.jpg IMG_20190705_231643275.jpg IMG_20190705_231703778.jpg IMG_20190705_231709206.jpg
    5-off them will be held in a fancy curved frame, made from oiled mahogany. (actual mahogany, not sapel)
    These are the steel templates for the ends to give an idea -
    The whole thing is to mount fancy electronics in. It's a functional but also artistic job.
    Now the "standard" way to finish these is just to powder coat them in black, but I'm looking for something more special.
    What I'm toying with is some sort of forced rat-rod style patina. But then I'd want to clear coat it over. I'd want it fixed, not "evolving" (ie not continuing to rust)
    I think that a bit of red on the steel will blend in the colours with the mahogany ends and make for a quality and interesting job.
    You can get patina via rust then electrolysis, but it's black / grey, and I'd like it a bit more red.
    So there's the background.
    So, two things -
    A) does anyone have any general idea
    B) clear coat over rust. Is that going to work in any way at all? I'm talking light rust, and not flaking, but clear coat is supposed to stick to base - I mean it's not a primer!
    So what would you do? Again it's a artsey job, and I'm after technique, rather than subjective "rat rods are stupid" comments! : )
    Thank you.
  2. angellonewolf
    angellonewolf Member
    4,921
    bristol england
    when i restored my vice that was rusty all i done was wax it a few times you can do the wood at the same time ?
    how you rust it im not sure but sure i seen on here there is a bought gel etc that you paint on and does it in a half a week
  3. Fazerruss
    Fazerruss Member
    2,538
    West Yorkshire
    Don't know if this will work but....
    Chuck come off cuts of steel in a bucket and lightly water with a watering can every day ( this may only take a day or two).
    Then lay the panel on a flat surface and pour over the rusty water and leave to dry.
    Clear coat the resulting effect (hopefully not a mess!)
  4. julianf
    julianf Member
    4,428
    devon, uk
    I've done waxed stuff before, and it's fine, but I don't want to force upkeep on the end user.
    In my head, I'm seeing a glossy clear finish with the rat finish under.
    Kind of like it's been vac packed?
  5. Ruffian Member
    2,105
    Devon UK
    We used to paint it red/orange/brown camouflage first kinda pattern.
    Then the top coat and then scorched areas to break through and re show the reds for worn rust spots.
    Then lacquered that.
  6. julianf
    julianf Member
    4,428
    devon, uk
    So completely fake - ie all paint, no actual rust?
    Ruffian likes this.
  7. julianf
    julianf Member
    4,428
    devon, uk
    I suspect I can get the rust easy enough. I thought a dip in a caustic soda bath to take everything back to metal, and then a dousing in somthing like vinegar would do it pretty much instantly.
    But then I need to get something over the top of that.
  8. Ruffian Member
    2,105
    Devon UK
    Yep completely fake but distressed looks.
  9. chunkolini
    chunkolini celebrity artiste
    8,656
    Swansea
    Have a look for rusting paint.
    Perfect for the job and used in loads of custom car projects
  10. stuvy
    stuvy Member
    You can even get vinyl wrap in rust effect
    I know someone that buried his cars wing after stripping the paint off it and poured milk over it. It rusted in no time
  11. jimbo84 Member
    985
    Up North
    Hydrogen peroxide hair dye
    Wiped down
    slim_boy_fat, dobbslc and stuvy like this.
  12. 8ob
    8ob Forum Supporter
    5,183
    moscow on thames
    I can lend you a Jack Russell for a few days, they have a single jet wide angle patina enhancing gadget built into their undercarriage :thumbup:
    Bob
    Morrisman, mtt.tr, rtcosic and 11 others like this.
  13. julianf
    julianf Member
    4,428
    devon, uk
    So there are loads of ways to get the patina.
    But again, I think the real question is, will clear coat go over it reliably?
    What specific products should I be going for? And any application tips?
  14. julianf
    julianf Member
    4,428
    devon, uk
    Had a quick look. Looks good in the photos, but the one I saw was £100 for 5 sq MTRS, which is probably half that on an awkward shape, and I fear thats quite a lot of cash Vs some vinegar and clear coat?
    Have you used any yourself? If so, can I ask what brand? And did it work out nicely?
  15. stuvy
    stuvy Member
    A long time back we made some steel railings and the chap had them wet lacquered. It rubbed through in no time on the hand rail
    So he had it powder coated in clear lacquer and it was lovely and smooth but had the finish your after
    slim_boy_fat likes this.
  16. angellonewolf
    4,921
    bristol england
    surely if its wood then it needs some sort of maintance my vice its outside but under a canapy so sees all weathers but not directly all i do is wax it every few months
  17. arther dailey Member
    3,730
    Southampton England
    calcium chloride, mixed in water, normally comes in flakes, its used for fast drying concrete Without reinforcment, no doubt some will tell of the disasters with flats collapsing years back when it was used with reinforcing steel. need to nuetralise with plenty of water after use though.
    stuvy likes this.
  18. Anguz
    Anguz Forum Supporter
    528
    bedfordshire
  19. julianf
    julianf Member
    4,428
    devon, uk
    It's an indoor device, used to house electronics. I find that wax needs renewing even from general handling. In my experience, which may, or may not, be accurate, oiled wood lasts longer than wax on metal.
    Either way though, I'd like a fancier finish than I think wax is.
  20. julianf
    julianf Member
    4,428
    devon, uk
    Clear powder coat sounds good.
    If I can I'd like to do an in house job, and I'm not set for powder coat.
    I should setup really, as it comes up for me again and again, and it's only small parts that I get asked for, so a big catering oven would probably be large enough for anything I ever have to do.
Advertisements
