First welds... What am I doing wrong?
  1. niels
    niels Member
    53
    Belgium
    I went for a bottle of gas this weekend and the store-owner kindly donated some cutoffs of 4 mm mild steel to practice on. So I did try to lay some beads and after playing with the settings a while I still didn't manage to get a consistent "prrrrrrrr" sound. The best I could get was a "machine gun burst"-like sound.
    So I did make a little video to show (mainly let you hear) the welding. Could you please elaborate on what I'm doing wrong?
    - Gasflow?
    - Wire speed?
    - Voltage?
    - Is the stick-out too much?
    - Position of the torch?
    Some notes:
    Yes, I did these welds in short sleeves because I was actually cleaning up when I realized I could make a small video. Normally I would wear a long sleeved jacket.
    I dialed the burn-back to the minimum. I couldn't find a decent answer in the manual what the setting should be. As far as I understand it controls the "not sticking to the work piece" when stopping the weld. Since I didn't stick once, I kept it like that.
    I'm not sure how the tension on the wire feeder is set correctly. I loosened the tension until the roller started slipping when pressing the wire feed button and then I tightened it a notch.
    Is it normal that the wire reel is not running "smooth", but that it turns in jolts (correct word)? Although it looks like the wire is coming out of the gun with a consistent speed.
    - Niels
  2. grim_d
    grim_d Unlikeable idiot.
    3,097
    Scotland - Ayrshire
    It looks to me like your wire speed is too low.
    Depending on how it holds the spool it should turn pretty smooth, is your tension set correctly? Tight enough to feed the wire but it should slip if you put your (gloved!) Hand in front of the torch and try and feed.
  3. Matchless
    Matchless I started with nothing, still have most of it left
    1,626
    Essex UK
    looks like the wire is burning back so wire speed too slow, if you have the wire speed too fast for the current setting you will feel it hitting the work piece, BUT I am a self taught hobby welder....
  4. angellonewolf
    angellonewolf Member
    5,654
    bristol england
    as above im self taught
    but as said wire feed to slow turn it up untill when you push the trigger and you feel the torch pushing back as the wire hits the metal then turn it back till you get a constant buzz
    setting up the wire reel turn it need to be tight enough that it will let the reel roll easy but only tight enought as not to unreel itself once you release the tigger (hope im explaining that well enought)
    set up the wire feed is easy you want the 2 rollers to push togher as to feed the wire when the tigger is pressed but if you hold the wire in your 2 fingers as it come out the torch the wire should slip on the rollers or what will happen if the wire sticks as it some times does and welds its self to the tip you will get a birds nest of wire in the mechine
    https://www.mig-welding.co.uk/mig.htm have you looked throught this gives a lot of tips on starting welding
    slim_boy_fat likes this.
  5. Wozzaaah
    Wozzaaah The wizard of woz Staff Member
    15,196
    Wiltshire, UK
    Have you got a stitch weld timer turned on?
    Seems like very even intervals to me and those welds look pretty decent, much better than you’d expect from a poorly set up or performing machine.
  6. Wozzaaah
    15,196
    Wiltshire, UK
    Or are you pulsing the trigger every couple of seconds?
    Looking again at those welds on a bigger screen I think you’re worrying unnecessarily, they look very good indeed.
    metalmelt and angellonewolf like this.
  7. niels
    niels Member
    53
    Belgium
    Thank you all for the feedback. I did play a lot with the wire feed/voltage dials, but nothing changed. Tonight I gave it another go and once again the beads were laid in "bursts".
    I started playing with the wire feed tension, the tension on the wire spool and a nut in the wire spool shaft, but to no avail. I noticed the wire spool was not turning smooth, but also in "bursts". This was most notable when using the button on the torch rather than using the wire feed button inside the casing. As a result the wire slipped.
    So, I decided to change out the installed 0.8/1.0 wire feed roller with the 0.6/0.8 that also came with the machine. And voila... turning smooth as silk and a nice constant "prrrrr" sound.
    It turns out that you have to install the wire feed roller with the number corresponding to the wire size (0.8 in this case) facing inside the machine. I assumed that it was printed at the opposite side of the groove so that you could easily see which the wire feed roller was installed. With the 0.8/1.0 roller it was not very distinct which groove was which size, but with the 0.6/0.8 roller it was very obvious.
    Stupid beginner mistake, but at least nobody got hurt. :D
    - Niels
    duncans, Peloquin, metalmelt and 2 others like this.
  8. Ed. Member
    It does sound like a stitch timer is on but I don't think that machine has that function, at least I can't see it on the front panel. The other thing is that a stitch timer wouldn't give you that pulse sound between the timer off/on. It should be welding and then stop then start again, this sounds like it is pulsing during the actual welding time. Bonus feature!:clapping:. You have a pulse MIG welder now!
    Seriously though, I would be guessing that it is an issue with the machine itself, possibly a capacitor/contactor/electronic switch? problem, as the weld looks reasonable from what I could see.
    But it looks like I was wrong and you sorted it out, now do a video of it working properly.
    Cheers
  9. Robert Mullins Member
    112
    Salisbury, uk
    It's not a stupid mistake, it's easy when you know, I'm a time served welder, 1978/82, what your experiencing is not enough wire, a long arc, the arc will burn above the weld pool, you will lay a weld, but with minimal penetration, don't be afraid to use plenty of volts, and lot's of amps, the amperage is governed by the wire speed, keep the wire pushing into the weld pool, if the plate is thin, move quickly, if you burn through, keep ajusting the v& w/s down until you don't: it's so easy for me to say, but I've been welding more than 40 years: keep at it, you will get there,
    duncans, lewlux, a111r and 1 other person like this.
  10. Malky Member
    145
    Scotland
    Yes I’ve got different welders and they work the opposite, one with the sizes on the opposite sides and one with the size on the same side as the groove, confusing to say the least.
  11. slim_boy_fat
    slim_boy_fat Forum Supporter
    Your original 'burst' feed :welder:, now fixed, problem aside those look pretty good - keep it up. :thumbup:
    What does the back of your test piece look like?
  12. Benterrier Member
    72
    UK Hereford
    Good to hear you sorted out the problem. Just goes to show how wire feed is critical when setting up.
    Interested in your choice of the Jasic 160 and what do you think of it. Are you pleased and does it come up to your expectations?
  13. niels
    niels Member
    53
    Belgium
    Sorry, I didn't take a picture of the back and these pieces are now rusting in the scrap bin. I've been doing some exercises with scrap tubing and sheet that I acquire at a local metals dealer (or how do you call this in proper English?).
    I'll be taking a few sessions of one-on-one training in 2 weeks as I think this might be the most efficient way to get the basics right and continue practising with some personal fabrication projects.
    I'd no welding experience at the time of purchase and I can't compare it with other welders. I did want to buy a decent welder that can be used for car restoration work (0.8 up to 3~4 mm) and after a lot of reading and researching I've just decided on the Jasic. Partly because the price was only slightly over my budget and also because of the 5 years warranty.
    - Niels
    duncans and slim_boy_fat like this.
  14. Benterrier Member
    72
    UK Hereford
    I settled for the Autostar 160 (Jasic 160 clone) £200 cheaper with 3 year warranty.
    metalmelt and slim_boy_fat like this.
Advertisements
