wrinx
- UK
Wire arrived today so thought it would be rude not to crank up the new beast and have a play.
Found a few bits of grubby 3mm and 6mm scrap and stuck them together with very little cleaning up, playing about with the settings as I went.
One thing that became apparent, I was able to use maximum power without tripping the 20amp fuse fitted to the box (got a 25amp ready!).
I've realised I'm more than a bit rusty after being held back by an SIP! But this machine is soooo smooth I'm sure the welds will improve quickly!
The first welds on 3mm...flow is set at 10lpm but still a bit dirty, any ideas?
6mm to 3mm
Inside the 3mm angle, the first has pin holes, not sure why as the rest are ok
All criticism welcome...
wrinx
6mm to 3mm
wrinx
